Winter Storage And Rust...
Posted 28 December 2016 - 10:35 PM
I have been looking to purchase a Mini for quite some time and have finally found one, probably the wrong time of year but that's life!
However I am very nervous about storing it over the winter and am wondering if I should buy it...
Sadly I don't have a garage nor one I can use at present so it will have to stay on my drive.
I will of course seek to buy a quality cover and would like to run it at weekends when dry but am I running the risk of it rusting?
Are there owners who store their Mini's like this and if so have you suffered with rust etc?
Thoughts and advice very much appreciated...
Thanks...
P
Posted 28 December 2016 - 10:51 PM
Don't be too paranoid - if it's fairly rust free then treat any obvious, nicks, scratches, rust patches (at minimum, and concentrating on the easily available rub down slap some jenolite on, followed by some zinc based stuff and that should hold it pending proper repairs at your convenience / better weather........ a few coats of wax wouldn't hurt either.....
It won't dissolve being outside for winter and personally I wouldn't bother with a cover........ I'd be more worried about leaving it on your drive - make sure it has some security .....
Posted 28 December 2016 - 10:57 PM
It won't dissolve being outside for winterand personally I wouldn't bother with a cover........ I'd be more worried about leaving it on your drive - make sure it has some security .....
Many thanks for your reply. I did wonder about a cover as I had heard that they can do more harm than good.. As for security what are the best options?
Posted 29 December 2016 - 10:09 AM
With the desirability of decent minis only on the increase, worth of cars in parts, the ease of changing ID and their pathetic locks they're very easy to "liberate" - some easy free precautions - personally I'd park it in if at all possible disconnect the battery, remove the rotor arm put the steering on full lock, remove the steering wheel and take three wheel nuts off a wheel....(latter one a bit of overkill and you must remember you've done it - otherwise things could get very nasty very quickly)
....should make sure you've still got your car ready to be enjoyed come spring.....
Posted 29 December 2016 - 12:24 PM
If you leave a mini parked up in even a moderately dry garage it will rust, rubber parts will degrade, brakes will seize and the battery and tyres will go flat.
If you leave a mini outside unused, it will still rust along with the other stuff. But depending upon how good the window and door rubbers are, you'll mostly likely end up with damp mouldy carpets and seats too. A car cover seams like a good idea until it starts scratching the paint, trapping moisture witch will also ruin the paint.
The best thing you can do is just drive the bloody thing. It will still rust anyways, but at least with being driven the car gets to dry out and air and might be more reliable than a pampered one that never gets used. Just when it does come time to fix the rust, do it properly and not just slap some chemical treatment and filler or paint over it expecting it to go away, it won't. There is no such thing as surface rust on a mini as most of the panels rot from the inside of panels and seams first.
Posted 29 December 2016 - 12:44 PM
For security a Disklok should be used as your minimum defence......see tests in links below:-
http://www.autoexpre...s/95033/disklok
http://www.ovat.be/A...AutoExpress.pdf
Many Mini's have been stolen from peoples driveways, so if possible also block it in with a modern more secure car behind.
Special TMF section for reports of stolen Mini's:-
http://www.theminifo...en-mini-alerts/
Posted 29 December 2016 - 05:15 PM
https://www.machinem...instant-garage/
Edited by Sag, 29 December 2016 - 05:16 PM.
Posted 29 December 2016 - 07:38 PM
Posted 30 December 2016 - 12:28 PM
A good quality outdoor cover with straps pulled tight & a disklock as a bare minimum. I have disklocks on all our cars and can't stress how important they are, they're the only reason we still have one of them as the theiving scum couldn't get it off even with the key!. Worth every penny in my opinion.
Posted 30 December 2016 - 01:00 PM
Sorry but this just isn't true. You would be crazy to drive a classic Mini, especially a restored one through winter if you don't have to. With the quality of a lot of the parts these days they will be rusty come next years summer from our experience! And that's even if you're using decent products like Bilt Hamber to protect them.
Posted 01 January 2017 - 03:02 AM
It's a car, designed to be driven.
Even a restored one will rust again one day.
Might as well get out and use them, or sell them to someone who will :)
Posted 01 January 2017 - 10:20 AM
Posted 01 January 2017 - 10:21 AM
Posted 01 January 2017 - 12:02 PM
Exactly, or other wise al these barn finds would be in immaculate condition.
Mine has been parked up on the dive for the last few months, so hasn't seen any salt this year (not that its really been cold enough this year). But the battery is now past a recharge, and there is rust already bubbling up behind the paint along the wing to front panel seams that were replaced 2 years go.
Posted 01 January 2017 - 12:55 PM
Why, because it's just so much fun. The price of replacing panels every 8years or so is worth it!
