#16
Posted 29 December 2016 - 01:04 PM
#17
Posted 29 December 2016 - 06:24 PM
£42 including vat for 10 minutes work to plug a code reader in, select vehicle type and to press a button to read fault codes is having a laugh.......
If you can find a garage who charges £20 use then because most around me charge min of £35 and then stick vat on!
Having said that, I have just noticed that you live in Buckinghamshire.
That's why! Get closer to London and it goes up .. 8-{
#18
Posted 30 December 2016 - 11:44 AM
Got one ordered and pickup today from our local auto save (Keep it local) Got a Bosch one for £85 will got it fitted today and get codes cleared and hopefully that will be the end of this one for now :)
#19
Posted 01 January 2017 - 05:03 PM
Hi Guys,
Well a straight forward job almost ended up in a nightmare. Looks like the previous owner had attempted to remove the sensor but failed as the head was rounded. With a bit of heat and a 21ml socket (Not the 22) we managed to get it out after 2 hours or so and ended up with very little thread left to put the new one in but managed. Cleared fault codes and ran a check and all is ok. Many thanks for all you input. It really has been appreciated.
A Happy new year to you all
Alan
#20
Posted 01 January 2017 - 07:17 PM
#21
Posted 01 January 2017 - 08:03 PM
Glad you got it sorted in the end.
Happy New Year!
#22
Posted 04 January 2017 - 11:12 PM
Or try Euro Car Parts. They have 69% off if you use the code XMAS and the stock Bosch too
It was actually 'up to 69%' .. I got about 35% off an air filter on Tuesday using the code (Renault part).
And it's not just fleabaay parts. Years ago my Alfa was fitted with an NTK lambda sensor (part of NGK group). The car was never quits right and after a few thousand miles the eml light would come on intermittently. Turns out the Bosch lambda is 8ohm and NTK 4ohm.
And like good plugs lambdas have a life of around 60k miles too.
Edited by gazza82, 04 January 2017 - 11:18 PM.
#23
Posted 30 January 2017 - 01:45 PM
Maybe next time he buys a car he'll buy a drivers handbook/manual,save himself a lot of grief
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Lower Radiator Bracket Fitment IssuesStarted by DAC1952 , 09 Mar 2025 ![]() |
Automatic GearboxStarted by astracass , 25 Feb 2025 ![]() |
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Start Motor Grind No Engine Turn OverStarted by MrNowell , 16 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
