Started yesterday and finished the basic build today. It is held together with some worktop screw fittings. The individual pieces were test fitted to try and work out were they sit relative to each other but screwing it together has been a bit of a guess so not sure if its going to fit.
On the plans it doesn't really show you where the two centre pieces fit so these were a guestimate with some measuring and looking at photos of consoles
I was going to try and build it in the car but there is no way to get at the screws. I also tried to fit it in the car but it looks like the seats need to come out :-(
I was going to cover it in Vinyl but there may be too many corner edges so I may just paint it? Not sure what to use as edging either?
Also I messed up the R/H side (when sitting in the car). The cut out for the Heater is too low. I may redo that side but I may need to chop a load off to give access to the clutch?
I guess with the seats out the console should slide in place?
Edited by JonnyAlpha, 22 December 2016 - 08:40 PM.
