Very Tight Gear Changes
1 reply to this topic
#1 DavidLamb
DavidLamb
  • 20 posts
Posted 20 December 2016 - 06:38 PM
Looking for a bit of advice chaps, hayabusa is playing up again. I changed the gear cable recently, got about 500 trouble free miles. Now it's ridiculously hard to change gears at any time hot or cold and when sitting in 1st and give it a rev it's creeping forward. When the engine is not running I can change gear without issue the stick is nice a free. My thoughts are its the clutch? I have changed the friction plates but the ones that came out looked to be in perfect condition. If it is the clutch is it hard to do with the engine still in the car? Cheers David.
#2 Painter man
Painter man
  • 85 posts
Posted 20 December 2016 - 09:09 PM
Hi david give me a call on 07967 565286 i also have a busa with a qba axle should be able to help you out i used to race f1 sidecars mine was r1 powered but did loads of clutches craig
