Hif 38 Carb Fuel Adjustment
Best Answer Leonrjohnson , 13 December 2016 - 11:07 PM
HIF44, initial setting up
The initial settings for HIFs as opposed to HS versions of the SU are as follows:
1. Run the engine to working temp. Obviously you can't always do this but I think this is recommended because of the temperature compensation on the jet in HIFs. You may have to repeat this procedure once the car has been
started and warmed up.
2. Remove the piston and suction chamber.
3. Unscrew the throttle adjusting screw until it is just touching its stop with the throttle valve shut
4. Make sure none of the cold-start or choke features are engaged.
5. Turn the throttle screw 1 1/2 turns clockwise.
6. Check that the needle guide is flush with the bottom of the piston.
7. Turn the mixture adjustment screw until the jet is flush with top of the jet guide. Then turn the screw 2 turns clockwise.
8. Refit the piston and suction chamber.
This should give you a good starting point. I've used this method many times. It is also good to check that the throttle plate (butterfly) is closing all the way.
Remember: Mixture screw clockwise is RICH (screwing in) so OUT (anti clockwise ) is LEAN
Go to the full post
Posted 13 December 2016 - 10:51 PM
I know where and what to adjust,
Which direction do I turn the screw to lean it off? Need to lean it off as its way too rich(gulping fuel!)
Thanks guys
Posted 13 December 2016 - 11:05 PM
Screw it out to lean it off, counter intuitive I know.
Posted 13 December 2016 - 11:07 PM Best Answer
Posted 14 December 2016 - 10:51 AM
Great post, I'd trawled the forum and google looking for this!
Thanks folks
