Type R Cooling
3 replies to this topic
#1 Mallery10
Mallery10
  • 38 posts
Posted 04 December 2016 - 10:07 AM
Looking for some help to ensure type r is cooling correctly.  Car feels like it take a good 10 mins at idle for the thermostat to open and the cooling system start to flow.  The output hose from the head gets really hot and you can feel the water boiling as it leaves the head.  As the cooling system is so long in comparison to the original car I'm worried that the engine is overheating before the thermostat opens.  I've tested the stat and it opens ok in the 2 stages (pan on hob).  I've put the fan sender unit near the top hose and its switching on the fan before the stat is open. Anyone had similar issues?  Should i run without a thermostat?
Appreciate any help
#2 KTM kid
KTM kid
  • 227 posts
  • Local Club: Crews missels
Posted 04 December 2016 - 11:00 PM
Hi sounds like you may have air locked in system. is your header tank higher than the cylinder head? are there any kinks in hoses?
#3 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 05 December 2016 - 01:01 PM
Would you like to do a basic sketch of how you've plumbed it all (maybe photos of it all) so we can have a look and see if something is not quite right......
#4 Mallery10
Mallery10
  • 38 posts
Posted 05 December 2016 - 10:02 PM
Header is highest point.  Ill do some pics thanks
