new bmw mini engine in classic mini?
47 replies to this topic
#31 PhoenixSimon
PhoenixSimon
  • 1,050 posts
  • Local Club: BOGMOC
Posted 14 September 2006 - 06:28 PM
The biggest thing about a bini s engine isnt the engine its the 6 speed gearbox its ruddy huuuuge. That would be a major problem if you want a cooper s motor, and then the mountains of electric rubbish, a b series vtec was made some 15yrs ago and hence doesnt have half the electrics of the bini.
Simon
#32 Lund
Lund
  • 1,864 posts
Posted 14 September 2006 - 06:34 PM
stick with British and get a Lotus Espirit V8 lump in
...With the Renult 5 gearbox that comes attatched to it as standard ;D:lol:
#33 Clubby1275GT
Clubby1275GT
  • 1,176 posts
  • Local Club: Birmingham Mini Owners Club / Bruuuums Mini's
Posted 14 September 2006 - 06:53 PM
just sellotape it all to the roof mr bean stylee, get a few funny looks like but u can put two fingers up when u go past at 140mph!
#34 Silicon Skum
Silicon Skum
  • 741 posts
Posted 14 September 2006 - 06:59 PM
I've been trying to keep out of this (tongue has teeth marks from biting...) BUUUT...
First off, bog standard MINI One has 90Bhp, Cooper has 115Bhp (more can be tweaked, usually about 138 ish BHP). Yes, the engine for the one and cooper AND the 'S' are all the same engine, just different ECU settings and a blower on the S. All can be converted into each other.
As for the wiring C**p that goes with the Bini, well I'd just junk the whole lot and start from scratch on the engine management side of things. The ECU is no different from any other ECU, just the bini has a Shed-load off other non-essential electrical gubbins that have been shoe-horned into the ECU and BDC control units. Any half decent ECU that is compatable with the various sensors (so that would be almost ANY ecu then) that are NEEDED to run the engine, then have the ECU chiped and remaped to that of a similar spec fuel / ignition map for a MINI ECU / engine. DA DA! a running engine. It's not rocket science, you just need to get a simpler ECU that will work with the parts it connects to, and it's all fairly standard stuff found on any injected car. the trick is to remap the ECU to work correctly with the engine. If it's not NEEDED to make the engine run safely, leave it out.
Remember: "what does it do?, How well does it do it? and What does it do for ME?".
Now by this point the Bini engine will be about as comlicated as the MPI 'A' series, and will have about the same ammount of wiring and tubing / pipe work etc.
Oh, and NO whine from the power steering, as that is not fitted, wouldn't fit the Mini steering rack anyhow, besides that the whine is because the steering pump is electric so it doesn't draw any power from the engine, which is actualy quite a good idea, even if the car does sound like an Airbus A380 aircraft testing the rudder.....
Now comes the tricky part - cramming it into a Mini engine bay......which is about as hard as it is for the usual 16V / V8 lump transplants. So new subframe needs to be made to fit, probably some body adjustments etc.
Now this brings us to the next thing mentioned - The hight of the engine........
Just been out and looked at mine, doesn't seem to be THAT much of a difference in hight, *maybe* two inches at most. So, you could either :
A ) hang the engine an inch and a half lower (adjust whatever neede on the way) and manipulate the bonnet / engine bits to fit.
OR
B ) just stick a ruddy great bonnet scoop / bump / molding / etc. into the top of the bonnet to fit around the engine.
Job done.
SS
#35 nev_payne
nev_payne
  • 2,249 posts
Posted 14 September 2006 - 10:52 PM
I wouldn't say Nev is particularly right...
Yeah ahem I was being a little anti-bini in that little speech ;D
#36 jake
jake
  • 57 posts
Posted 17 September 2006 - 02:04 PM
just to add about someone mentioning a lotus engine in a mini,
this is now for sale
http://cgi.ebay.co.u...Vie...A:IT&rd=1.
so you should definately try a cooper engine, or something similar
#37 Jobu
Jobu
  • 508 posts
  • Local Club: 16vminiclub
Posted 17 September 2006 - 02:36 PM
But that Lotus engine is just a K series engine so nothing new as such...
Regarding the Bini engine, size it up and try, anythings possible.
#38 who_loves_the_mini?
who_loves_the_mini?
  • 1,314 posts
Posted 25 November 2006 - 03:04 AM
Bringing this up again, does anyone have the dimensions of a new mini engine?
#39 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 25 November 2006 - 07:55 PM
wasnt that on page 2??
#40 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 November 2006 - 07:59 PM
yep
External dimensions Length x Width x Height (mm)
590 x 465 x 675
#41 fikus01
fikus01
  • 1,910 posts
Posted 25 November 2006 - 08:02 PM
dont forget there is a gearbox to add to that!!
#42 who_loves_the_mini?
who_loves_the_mini?
  • 1,314 posts
Posted 25 November 2006 - 08:41 PM
thats what i was after, the complete engine and gearbox dimensions
#43 *DJH*
*DJH*
  • 4,972 posts
Posted 25 November 2006 - 09:36 PM
Im Pretty Sure You Can Fit Any Engine Into A Mini, I've Seen A Land Rover 4.0 TDi Engine In One.
#44 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 November 2006 - 10:40 PM
well you do have a box 10ftx5ftx5ft ish :xxx:
or did you mean connected up and working ?
#45 *DJH*
*DJH*
  • 4,972 posts
Posted 25 November 2006 - 11:08 PM
Ha Ha, Yes I Do Mean Working :)
