Crankcase Breathers
18 replies to this topic
#1 Shaggy33
Shaggy33
  • 311 posts
Posted 15 November 2016 - 10:51 PM
Is there any reason why I can't just have a short length of hoses with the filter on the end of my two breathers (one on clutch housing and the other on the timing chain cover)? Then block off the unused outlet on my hif44 carb.
Also can someone just clarify (I know, I know I think I've asked this before...!) where I run the two hoses to that come out of either end of my inlet manifold?
Many thanks
#2 Dusky
Dusky
  • 5,322 posts
Posted 16 November 2016 - 05:07 AM
I wouldnt. Crankcase breathing is important and those breather filters arent really breathing,nor filtering. I ran into All sorts of problems on my New engine untill I connected the breathers to the carb.
The heated manifold is most of the Time connected to the heater tap on the head, then through the heater matrix and Back into the bottom hose.
#3 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 07:52 AM
Thanks Dusky. I'm not running heater so I assume I run hose from heater control valve on top of engine block into manifold then back out the other side to the branch off pipe on the hose that runs from bottom of rad to engine block?
As for the breathers, good point. I think I read somewhere that others had done this that's why i suggested it but if you had issues I will follow the correct path!
#4 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 07:57 AM
Sorry one last question, I have only two breather outlets on the carb - one for float bowl which I assume just runs down to somewhere safe at bottom of engine bay and one crankcase breather. Where does the second chamber hose feed to?
#5 imaparana
imaparana
  • 580 posts
Posted 16 November 2016 - 08:33 AM
if ive read this correctly then you connect the other outlet up to your crankcase breather.
#6 Dusky
Dusky
  • 5,322 posts
Posted 16 November 2016 - 08:43 AM
I join them with a Y piece.
And yep, I dont Run a heater matrix either after it started leaking quite spectacularly :D
#7 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 08:46 AM
I wish I could find a clear diagram of photo of a 1275 mini engine bay that shows all the plumbing routing!
#8 nicklouse
  • 18,576 posts
Posted 16 November 2016 - 09:07 AM
they vary, and the heated manifold is not needed to be plumbed.
if a road car I would pipe the breathers to the carb.
I would also post pictures showing what you plan on connecting to what as you may not be referring to what we might think you are.
there is only one breather port on the carb for instance.
then there is the fuel overflow. you do not want to mix them up.
#9 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 09:52 AM
Here's some pics, first lhs of carb
And breathers;
First timing chain cover side (you'll see I've blanked off coolant hose as I though this branch went to the heater matrix which I've removed
Clutch side breather
And inlet manifold outputs
A complete klutz guide to hose routing would be appreciated!
#10 panky
panky
  • 1,790 posts
Posted 16 November 2016 - 10:25 AM
You might be able to work it out from this pic
The 'T' piece is just above the heater take-off hose.
#11 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 11:32 AM
cheers for this. So you hose from heater valve (albeit you've removed that) goes into manifold) and the hose from crankcase breather on clutch housing goes into t-join which one end goes to carb and the other end goes to the breather on timing chain cover.
#12 Ethel
  • 25,919 posts
Posted 16 November 2016 - 11:58 AM
The Y piece also acts as a reducer. If you're plumbing in the water heated manifold separate to the heater valve you might want a restrictor so it doesn't rob too much flow from the radiator. Also check your pipe diameters, it looks like your manifold is 5/8" and bottom hose 1/2". You could use 12G2534, 5/8" hose and an adapter at the bottom hose end. Fancy alloy heater take offs are also available.
#13 panky
panky
  • 1,790 posts
Posted 16 November 2016 - 01:58 PM
Yep, but the heater valve is the in-line type by the bulkhead.
#14 Shaggy33
Shaggy33
  • 311 posts
Posted 16 November 2016 - 02:54 PM
do I need the the heater related hoses fitted to the manifold etc for starting the engine and just checking it runs etc
#15 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 16 November 2016 - 03:05 PM
No. You might not need them connect at all.
