Idle Rpm Too High.
9 replies to this topic
#1 Someone called James
  • 26 posts
Posted 13 November 2016 - 09:21 PM
Hello Guys and Girls,
Ever since I bought my mini, a 1989 998cc Racing Flame in February 2016, the Idle Speed has been too high, usually at about 1000-1200rpm once the engine has warmed up. The previous owner said that they had "modified" the carburetor (a single SU HS4) to make the engine more "reliable" or something along those lines.
I've checked the condition of the spark plugs and these show the mixture seems OK and wound the idle speed screw out as much as possible until it makes no difference. The throttle and choke cables aren't too tight so I'm out of ideas.
I'm going to strip the carb down in the future before fitting on my rebuilt engine but I don't want the same problem to happen once I've rebuild it!
James C.
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 14 November 2016 - 03:12 PM
Try manually holding the throttle back to see if revs drop. Could be that the butterfly valve wasn't assembled correctly. Or a big air leak.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 14 November 2016 - 03:33 PM
Or the return spring bent, bent jet... A lot of things
#4 Scousemouse
Scousemouse
  • 358 posts
Posted 20 November 2016 - 11:47 AM
My tick over went up from 1000-1100 to 1200-1300 after I had refixed the choke cable after it pulled out thru the cable nipple upon starting up one morning.
Evidently it was down to me rushing and not checking the choke was fully open when off.
(must get around to fitting new nipple) but on 1000-1100 the engine is quiet + smooth.
Question ...what is the correct rpm on tickover for a 91 998cc???
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 20 November 2016 - 05:38 PM
850+-50 rpm
#6 Someone called James
  • 26 posts
Posted 20 November 2016 - 08:43 PM
Thanks for the suggestions, I'll try holding the throttle back and see if that makes a difference. I'm going to rebuild the carb at some point so some of the internals will probably be replaced.
Thanks,
James.
#7 Scousemouse
Scousemouse
  • 358 posts
Posted 20 November 2016 - 09:18 PM
850+-50 rpm
I'm using the tacho(nippon) off the original 3 clock dash,wonder if this tacho is goosed as when it shows 1100 on t/over the engine don't seem to be racing??
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 21 November 2016 - 10:15 AM
Could be the voltage stabiliser(although I'm sure the tacho is a separate feed)
#9 Scousemouse
Scousemouse
  • 358 posts
Posted 21 November 2016 - 12:44 PM
Yep tacho is separate.
#10 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 21 November 2016 - 04:56 PM
In that case I'd be verifying engine revs and tacho revs are the same
If not you have an issue somewhere
Edited by cal844, 21 November 2016 - 04:57 PM.
