Race Pedalbox For Mini Classic
4 replies to this topic
#1 ilmung
ilmung
  • Just Joined
  • 49 posts
Posted 06 November 2016 - 06:36 PM
I have a Midas mini and I want  to install a pedalbox like the obp example in annex .
I just wonder if already someone installed this  already in his mini and if it's plug and play or do you need to do some modifications ?
thanks
#2 nicklouse
  • 18,579 posts
Posted 06 November 2016 - 06:56 PM
Certainly not plug and play.
Also nor sure how the Mini pedal box fits on the Midas. As some thing like the box shown will need extra parts to attach it to the body and the Midas my not ha suitable strength for it.
You will be better looking at ones that have been made to work with a Mini pedal box.
One thing you are lucky with is you do have space above the pedal box.
So you could do a split adjustable set up to bolt on there using the standard pedals.
#3 ilmung
ilmung
  • Just Joined
  • 49 posts
Posted 06 November 2016 - 08:03 PM
Thanks for the reply !
OBP informed me that this pedal box fits in a mini classic with very little modifications , so I taught that
the pedalbox would fit also in a Midas MKII even with some modifications .
I do not have fear for the strenght of the polyester fibre body as the thickness is very high , I could also renforce the area , but I do not want to cut parts out of the body .
I read your profile and topics , very impressive !
#4 grizzler73
grizzler73
  • 300 posts
Posted 12 November 2016 - 08:46 PM
You might be better to look at the KAD bias box that bolts on the top of the mini pedal box, nice design too.
#5 ilmung
ilmung
  • Just Joined
  • 49 posts
Posted 14 November 2016 - 04:10 PM
Yes KAD bias is a nice thing  , but as I put a suzuki engine in the Midas I need more room in the engine department , especially between the inlet and the opposite site .Just there  you have the master cylinders and other parts
Edited by ilmung, 14 November 2016 - 04:11 PM.
