1275Gt @ Mill Road Garage Isle Of Wight
770 replies to this topic
#721 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 15 March 2025 - 01:59 PM
While I had the wheels off for the tyre change I noticed that the steering rack gaiter was showing some wear/cracks, looking back a new rack was fitted in January 2020, so the gaiters have lasted 5 years, got to say changing the drivers side was frustrating and difficult whereas the passenger side only took 10 minutes from start to finish.
#722 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 20 March 2025 - 06:10 PM
Even though when replacing the steering rack gaiters I refitted the track rod ends in the same place, I thought I would check the tracking using a purchase from e bay, all checked out ok
#723 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 21 April 2025 - 05:26 PM
Decided to fit an additional steady bar to the radiator side of the engine, luckily there was already a hole in the subframe so no drilling required, I also changed all the other steady bushes. I then took it for a little run and parked a few cars away from this beauty.
#724 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 09 May 2025 - 05:32 PM
On the return home after a 700 mile journey attending the Cornish Riviera run the mini developed a minor exhaust blow, when I got it home I identified the blow from the Y Piece where it goes into a single pipe, I thought I would check for tightness when this happened.
https://imgur.com/a/A1vxx2e
I then removed the complete exhaust and refitted it with new clamps.
https://imgur.com/a/yWqGgu9
Also I was pleasantly suprised that I managed to achieve 45 MPG on the way home :D
Edited by JXC Mini GT, 15 May 2025 - 03:44 PM.
#725 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 12 May 2025 - 05:52 PM
My Mini was fitted with a Quick release rod change gear selector coupling when I purchased it, I have been struggling with selecting 3rd gear for a while, so today I changed it back to the standard sleeve and roll pins, the difference is amazing I can now select all gears much easier, feeling very pleased with myself.
#726 Fred&Rex
Fred&Rex
  • 127 posts
Posted 19 May 2025 - 07:32 PM
Just a quick question, how close is your Y piece to the tunnel/ floor, mine is very close and wondering best way to tackle this .
Daz
#727 KTS
KTS
  • 2,490 posts
Posted 20 May 2025 - 07:23 AM
one way to tackle it is through adjustable engine steadies; depending on clearance between the carb and bulkhead, tipping the engine backward will move the y-piece away from the bodywork.
#728 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 20 May 2025 - 05:08 PM
Daz
The Y piece has about 25 to 30mm clearance, but I do have adjustable engine steadies so could alter the clearance should it be required.
#729 Fred&Rex
Fred&Rex
  • 127 posts
Posted 20 May 2025 - 05:33 PM
Thanks for your input, I might try tilting engine back
Great idea
Daz
#730 Colinmac1330
Colinmac1330
  • 273 posts
Posted 03 June 2025 - 08:33 AM
How do you find these tracking gauges? Worth a pop?
#731 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 03 June 2025 - 04:45 PM
I think for £30 they are worth the money, lots of garages will check the tracking for free if you're having tyres fitted, but will charge £35 upwards for for any adjustments.
They're obviously not as good as laser tracking but are ideal especially if you are rebuilding your steering/suspension.
I would add that it is more accurate and easier to use with an additional pair of hands.
#732 Colinmac1330
Colinmac1330
  • 273 posts
Posted 04 June 2025 - 10:06 AM
Thank you.
Do you have a link to the ones you bought?
#733 simonaoz
simonaoz
  • 24 posts
Posted 04 June 2025 - 10:23 AM
I use one of these http://www.trackace.co.uk/ very accurate. Demon Tweaks sell them.
#734 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 04 June 2025 - 04:44 PM
Thank you.
For some reason I am struggling to post the link, the description is:-
2Pcs Wheel Alignment Tool Toe Plates Accurate Measure Tape And Conversion Chart supplied by quantum.trade
Also the price has dropped to £23.99
Edited by JXC Mini GT, 04 June 2025 - 04:45 PM.
#735 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 14 June 2025 - 01:55 PM
The Mini had a good run out to Beaulieu where I purchased a new steering wheel and front mats, I then went on to the Isle of Wight for a week, while there I popped in to see Ben to arrange for some work to be done later on in the year, the car has however developed a creak from the front suspension (front knuckle joints ?) and an exhaust blow as a result of going over a very high speed hump.
https://imgur.com/a/aKw7Va3
Edited by JXC Mini GT, 14 June 2025 - 01:56 PM.
    Bing (1)
