1275Gt @ Mill Road Garage Isle Of Wight
770 replies to this topic
#466 MikeRotherham
MikeRotherham
  • 1,031 posts
Posted 11 January 2020 - 11:47 AM
That work on the bonnet is really something else!
Just imagine the people who used to build these bodies multiple times a day. I know they would have had jigs and such like to line panels up but getting doors and bonnets to fit and by necessity at some speed. I have nothing but respect for them for their skill.
#467 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 January 2020 - 11:11 AM
The weld on the underside of the bonnet is visable.
I have ground it flat but not flush as I don't want it to go to thin.
When I prep the bonnet, I shall scrape some stopper over the area so that once rubbed down and painted it won't be visable to the eye.
I have used this method on new bonnets in the past and have been able to successfully grind the back of the weld flush but the metal on new bonnets seems to thicker than the originals.
Ben
#468 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 January 2020 - 03:50 PM
I haven't done much on this the past few days due to inspecting and quoting a new arrival as well as a few other odds and ends.
I finished the bonnet repairs. Ended up having inner frame and outer skin repairs on the front edge
And then I have been prepping the car for primer
Ben
#469 ClassicBRG
ClassicBRG
  • 78 posts
Posted 15 January 2020 - 03:35 PM
Today, I started by welding on the n/s wing and A panel
Then I mocked up the grille again so that I can finalise the position of the slam panel
Then I welded that in place before repairing and refitting the brace
Next, I installed the bonnet lock and rubber buffers and finalised the position of the bonnet.
With the bonnet locked, the pin sits exactly in the middle of the lock which is great
And here are the gaps as they stand
I'm not happy with the gap on the n/s. It's still too wide at the back and there is nothing else I can do except slice and dice the bonnet.
A simple process that starts with cleaning back the paint
A splash of zinc to really show up the bad bit and a pencil cut line
And then after cutting it, I moved the edge to where I want it. The spanner is there because it happens to be the exact thickness of the gap at the front that I am aiming for
Then tack it to check the gap again
And then fully weld....slowly!
Ill finish it fully during prep.
And thats done
Just the headlamp panels to fit now and a few little bits and then I can prep it for paint
Ben
Nice job on the bonnet!
That's a job I also need to do because the gap on my bonnet is too wide on one side.
But I am afraid the bonnet will warp after the weld job, and I might need a lot of filler to solve that..
Can you give me a little advice on that?
#470 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 January 2020 - 09:41 PM
And thats done
Ben
Yeah sure.
The best advice I can give is to work slowly. Once you have sliced the bonnet and moved the edge to where you want it, it is very important that you get the edges of the join completely level to one another and then tack weld them together at intervals of around 3 inches.
You need to be very careful that you get a good tack first time so a very quick squeeze of the trigger is all you need. In the case of this bonnet, the gap to weld back up was fairly big at the back of the bonnet so you need to avoid too much heat. I achieve this by using a copper backing beneath the join. This makes life easier as well as acting like a heat sink.
Once tacked, gently grind the tacks flush so that you can double check everything is still flush and then proceed with welding up the join by placing tacks between your tacks and then repeat until all the gaps are filled. Cool the area as you go with either compressed air if available or a wet rag or just wait between tacks.
Only other advice particularly with clubman bonnets is to set the height on the buffers and install/adjust the bonnet catch before starting. I also placed shims (in my case spanners as they were just the right thickness) between the bonnet and wings to wedge it into a central position and keep it there.
Hope that helps
Ben
#471 ClassicBRG
ClassicBRG
  • 78 posts
Posted 16 January 2020 - 01:31 PM
Hi Ben,
Thanks a lot for your advice!
When temperature in my garage is a bit higher, I will try to perform this job on my bonnet.
The mistake I made in the restoration process of my front end is that I welded the front and the wings together before they were on the car.
Now there is not much possible to adjust the gaps.
At that time I didn't own a welder myself, so I went to a welder who performed the welding of the wings and the front for me.
Now I own a welder myself and I am trying to make all the gaps the best I can get them..
#472 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2020 - 02:22 PM
Time to go into the booth and up on the lorry stands for epoxy primer to be applied
Ben
#473 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2020 - 04:42 PM
Epoxy is quite slow drying so I have only had enough time today to flat the inside and seal up.
I have made a start flatting the bulkhead but its still a little too soft.
#474 70K1100
70K1100
    Formally Known as NOT850
  • 233 posts
Posted 16 January 2020 - 08:28 PM
I've always had a preference to the round nose mini over the clubman, but after seeing your restoration I'm liking the clubman a whole lot more.   Great work.   I wish I had access to someone of your talents and passion for the minis where I live.
#475 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2020 - 11:05 AM
More prep and sealing up
And then I tried out a new product that was offered by my paint supplier.
Well it's not a new product as such but it is a more affordable version of uPol Raptor and is tintable. My main question about it was what is the texture like?
I find Raptor to be too heavy and as I am trying to blend the new stonechip into the existing, that wasn't going to work.
Apparently this stuff is much finer.
I could have used my normal stone chip and ten topcoated it but it's very difficult to paint up under the wings with the car the right way up and in a fixed position.... very hard...
Anyway, I mixed it as suggested with some of the top coat and applied it
Not only has it saved me a step, its given better colour coverage than I could have done with the gun and it very closely matches the existing stonechip.
Its called Gravi Hel Armour skin for anyone interested.
Ben
#476 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 21 January 2020 - 11:13 AM
If only I was in the UK. My Mini would totally come to you for a full restoration of the paint and bodywork! Stunning work, Ben!
#477 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2020 - 11:16 AM
Cheers Vinay. That's made my day :-)
#478 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2020 - 04:05 PM
That's the inside painted
#479 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 21 January 2020 - 04:20 PM
Looking good Ben on the underside and inside, it's a pity that most of the inside will be hidden with carpet and trim.
#480 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2020 - 04:52 PM
cheers John.
Yeah, there is that but at least we will know its nice and clean underneath the trim :-)
