1275Gt @ Mill Road Garage Isle Of Wight
721 replies to this topic
#451 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 January 2020 - 04:37 PM
Happy new year everyone.
Back on the GT now and time to finish this front end off.
Continuing on from lat time, I finished fitting the lower dash rail
And the trim retainer was cleaned and put back
Time to mick up the front end
The usual process begins with bolting the front panel to the subframe
And then offering up the wings, headlamp panels and slam panel
I'm not looking to align everything nicely at the moment, I just want to get a feel for the fitment and see if there are any obvious issues
I popped the doors on and tacked on an A panel
And then popped the bonnet on
That side is a good start but the other side is not
The back edge of the wing is hard over so the bonnet needs to go that way which of course will widen the already slightly too wide gap on the o/s.
Not much I can do with clamps and screws holding it as its so hard to keep everything where you want it and be able to make adjustments.
Bonnet pushed over to centralise it helped the n/s but not the o/s so I started welding the o/s on confident that I could get the gap back within spec. This would then allow me to use the slam panel to keep the front edge of the n/s where it needs to be if that makes sense.
A panel welded to wing
And then wing to inner wing
And then wing to front panel
And then a bit of playing and shoving and we have a nice gap
Bonnet needs to come forward in that shot..
n/s looks better after being able to use the slam panel to align to
I still need to play with it some more but its a good start.
A few overall shots with the grille in to show where we are
I should have it all on by the end of tomorrow.
Ben
#452 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 07 January 2020 - 05:03 PM
Happy New Year Ben
Great work, the bonnet alignment is looking good, previously it had massive gaps down both sides.
#453 Jase
Jase
  • 1,166 posts
Posted 07 January 2020 - 06:01 PM
That looks better than factory.
#454 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 January 2020 - 04:58 PM
Today, I started by welding on the n/s wing and A panel
Then I mocked up the grille again so that I can finalise the position of the slam panel
Then I welded that in place before repairing and refitting the brace
Next, I installed the bonnet lock and rubber buffers and finalised the position of the bonnet.
With the bonnet locked, the pin sits exactly in the middle of the lock which is great
And here are the gaps as they stand
I'm not happy with the gap on the n/s. It's still too wide at the back and there is nothing else I can do except slice and dice the bonnet.
A simple process that starts with cleaning back the paint
A splash of zinc to really show up the bad bit and a pencil cut line
And then after cutting it, I moved the edge to where I want it. The spanner is there because it happens to be the exact thickness of the gap at the front that I am aiming for
Then tack it to check the gap again
And then fully weld....slowly!
Ill finish it fully during prep.
And thats done
Just the headlamp panels to fit now and a few little bits and then I can prep it for paint
Ben
Edited by Ben_O, 08 January 2020 - 05:00 PM.
#455 KTS
KTS
  • 2,420 posts
Posted 08 January 2020 - 05:17 PM
nice work with the welder Ben !!
#456 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 08 January 2020 - 06:24 PM
Wow Ben, I thought yesterdays bonnet gaps were much better than before, but as always your attention to detail and aim for perfection means that the gaps now are absolutely spot on.
#457 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 09 January 2020 - 07:27 AM
as always fair play for the amount of work you put in the shell preps, the bonnet looks spot on and respect for taking the decision to cut and weld it
#458 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 January 2020 - 04:39 PM
Last little bits done today completing the fitting of the panels.Ill soon be on prep!
Headlamp panels...
They need clamping into place then screwed in so that the headlamps and grille can be fitted to check the headlamps are central to the frames.
About there I think. It's not really possible to get the headlamps fitting perfectly even to the frames as the headlamp adjustment  to set the beam will move it and screw everything right up so i'm only looking to get them central to the frame
Once happy, I welded them in
So that's the last of the panels to be fitted! horrah!
I still need to finish off the welding of the A panels and fold them round the A post return but Ill do that once I have striped the doors etc off. I also need to weld the front panel 'ears' to the inner wings but need the subframe to be out for that.
There is so much paint on the bonnet now that it looks really ripply. There is also some rust and holes in the frame work.
A new bonnet would be the best option but as they are just absol.... Ill stop there...
Best way to begin is to get rid of the layers and layers of paint
And a second go
Ill start the repairs tomorrow.
Ben
#459 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 09 January 2020 - 05:42 PM
There are quite a few layers of paint on there including the original black when I first got it
Ben
I think after your previous efforts to purchase a new bonnet without any damage, repairing the existing bonnet was the only option.
John
#460 Jase
Jase
  • 1,166 posts
Posted 09 January 2020 - 10:00 PM
Did you strip the inside of the bonnet as well?
#461 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 January 2020 - 10:18 PM
No. It really wasn't worth it. It has been painted black once by the looks of it so will only require basic prep and then painting.
Ben
#462 Homersimpson
Homersimpson
  • 829 posts
Posted 09 January 2020 - 11:10 PM
Looking stunning as ever, once again my hat is off to you :-)
#463 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 January 2020 - 04:42 PM
I have done some of the finishing off today
A panels
Not forgetting the stiffener
And the other side
Then I dropped the subframe out
So that I could spot weld the front panel 'ears' to the inner wings
Then I made a repair to the bonnet. The stiffening brace in one corner was rotted away causing the hinge mounting point to have lots of movement in it.
I got carried away and didnt get a before shot so I placed the old bits in shot when I realised
And with new metal in, its solid
I shall do the other repairs with the bonnet back on the car so that I can keep an eye on alignment particularly across the front
Ben
Edited by Ben_O, 10 January 2020 - 04:47 PM.
#464 Jase
Jase
  • 1,166 posts
Posted 11 January 2020 - 09:57 AM
Superb, that's the bit I was thinking of inside the bonnet Ben. Outstanding work.
#465 jamesquintin
jamesquintin
  • 1,017 posts
Posted 11 January 2020 - 10:05 AM
Nice work on the bonnet! I need to do the same with mine, What does the weld look like under the bonnet? Will it be noticable when the bonnet is opened?
Q
