1275Gt @ Mill Road Garage Isle Of Wight
770 replies to this topic
#376 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 19 October 2019 - 01:35 PM
Thought I would sort out my non-canceling indicators with a new indicator assembly, also pleased to get rid of some cable joints.
I have changed the handbrake rubbers for the 2nd time in 3 years with original replacements which hopefully will last longer
#377 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 November 2019 - 04:10 PM
Look who's back for a bit more :-)
Not actually booked in until Friday but I had some spare time so started the strip
This lot needs to come out first
That wont be going back in. Its being replaced with a new 1293!
Whilst its out, I am going to do the last of the panel work required on the front end.
So far, its inner wing O/S, outer Wing O/S and hopefully not too much more.
Ben
Edited by Ben_O, 25 November 2019 - 04:11 PM.
#378 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 25 November 2019 - 04:45 PM
Wow Ben, you don't hang around, could you add replacing the heater hoses with black to the other works.
Many thanks
John
#379 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 November 2019 - 04:59 PM
No worries
#380 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 25 November 2019 - 05:20 PM
Epic super work on this thanks for sharing and inspiring!
#381 Jase
Jase
  • 1,166 posts
Posted 26 November 2019 - 05:02 PM
Great to see a car so well looked after.
#382 floormanager
floormanager
  • 803 posts
  • Local Club: Mini Club Sussex
Posted 26 November 2019 - 09:11 PM
Good grief, it's back!
#383 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 November 2019 - 03:43 PM
Bit more done today.
Starting with removal of the subframe
And then the remaining front end parts and brightwork
Nothing more now than to cut off the front
I am going to re-use the front panel which requires just a few minor repairs but will be replacing both inner and other wings, a panels, scuttle and have now noticed it needs the inner wing to x member reinforcers too.
We knew the front end needed replacing some 3 years ago when it first came here but it was decided there was enough life in it so that the work could wait. Now the time is right and it really does need it
Ben
#384 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 November 2019 - 04:47 PM
Chop Chop
#385 Jase
Jase
  • 1,166 posts
Posted 27 November 2019 - 05:59 PM
Wow, is this a daily in between you getting your hands on it Ben?
#386 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 November 2019 - 06:01 PM
Not a daily but is used regularly.
I think we worked out in the 3 years since it first came to me, it hs covered approx 30,000 miles.
Ben
#387 Jase
Jase
  • 1,166 posts
Posted 27 November 2019 - 06:12 PM
That's good going, I don't think I was anywhere near that back in 87 :) and they were less than 10 years old then.
#388 floormanager
floormanager
  • 803 posts
Posted 27 November 2019 - 07:22 PM
Holy moly!
#389 GT Jimmy
GT Jimmy
  • 1,671 posts
  • Local Club: S.U.N.M.C
Posted 27 November 2019 - 07:38 PM
Good to see it's being used and not locked up in a garage
#390 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 December 2019 - 12:06 PM
Sorry guys, been off sick for a few days unfortunately so I'm now a bit behind.
Here is the front panel and front subframe that I removed ready to go off for blasting
Whilst I was away, they were taken over to Martin at MJG Grits to be taken car of and were waiting for me this morning back at the workshop
Considering how crusty the subframe looked, it has come up pretty much perfectly. I am surprised indeed!
And the front panel.
I now need to remove the remains of the old inner and outer wings from it and install a pair of new headlamp panels.
Under all of the filler was some particularly nasty welding
But that aside, its in fine fettle.
Now back to the car.
The rest of the inner wing remains need to be carefully removed. I started with the better side
Not too bad. Some minor repairs to carry out and some cleaning up to do but pretty happy with that.
Now the other side.... The worst side....
I drilled the reinforcer gusset and hit it with a hammer and it started to peel
hmmmmm...
Then I cut a chunk off
That is terrible and I am pleased that its being replaced. It is certainly in a state under the big patches. Folks, don't patch over rusty holes or this happens and you can't see it.
And this reveals that there are some unexpected repairs required
Ill get the rest removed and go from there.
Ben
