1275Gt @ Mill Road Garage Isle Of Wight
772 replies to this topic
#286 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 January 2018 - 09:08 PM
Wow, Ben, you work really quickly! The damage didn't look too bad in the pictures, but now it looks like it was never damaged in the first place.
It was fairly minor Vinay. Just the sort of damage that let the car down
I can't see any reason why it won't be prepped up tomorrow and ready to paint later in the week :-)
#287 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2018 - 07:38 PM
Not a huge amount achieved today. I got roped into making some sills and arches for an MOt failure car
I got the paint stripped from the repair areas
And uncovered the patched up scuttle end from before. It had cracked in the shunt so clearly wasn't going to last if patched again so I decided to weld it up
I have done some more prep but it was bits here and there so no photos today.
Ill get that sorted tomorrow when I finish the prep
Ben
Edited by Ben_O, 30 January 2018 - 07:42 PM.
#288 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 30 January 2018 - 07:56 PM
Great work Ben I prefer the after picture (with the weld repair), you may already have it in hand but can you do the same to the other side as it's probably in a similar state.
John
#289 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2018 - 08:02 PM
John
yep, it's not looking as bad the other side but will need welding I expect.
I have ordered your windscreen too
Ben
#290 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 30 January 2018 - 08:04 PM
Thanks Ben, I knew you would have it covered.
#291 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2018 - 08:04 PM
I removed the paint from the other scuttle end today.
Pretty ropey..
So I welded it up much like the other side
And then finished up the prep and moved it into the booth for matting, masking and eventually primer
And here it is after matting the paintwork on the lower half
Ill mask up in the morning and get the primer on and then the prep can continue
Ben
#292 johnR
johnR
  • 2,325 posts
Posted 31 January 2018 - 08:21 PM
great work (and that orange really suits a clubman)
#293 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2018 - 08:28 PM
Cheers.
I really like the colour too. It's very interesting in that in lower light, it looks quite dull, almost browney but in bright light, it looks like the colour of flames.
I think 'Blaze' is the perfect name for this colour
#294 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 31 January 2018 - 08:51 PM
There's a GT replica in Cape Town in a similar shade of orange and a GTS in orange too. I have to agree, orange is a great colour for a Clubman. May I share some pics of them here?
#295 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2018 - 09:33 PM
Go for it!
#296 Dutchdave's25
Dutchdave's25
  • 105 posts
Posted 01 February 2018 - 07:34 AM
Nice work Ben!
I do have one question for you though. judging by the bucket with water i assume you matted the side panel with water.
I've been told that filler attracs water, if thats the case than this seems like a risky operation.
Do you know something I dont? :)
#297 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 February 2018 - 08:38 AM
Nice work Ben!
I use a matting paste on a damp scotchbrite so i'm not saturating the panel. I don't matt over the filler so it only really gets the odd run of water going onto it which is immediately wiped off and then the panel is thoroughly dried.
The booth is also heated so any damp or moisture is quickly evaporated.
The filler in the panels is a very fine layer too so much less chance of absorption compared to a thick layer which may suck lots in and hang onto it.
Ben
#298 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 01 February 2018 - 10:29 AM
Go for it!
Here's the GT replica. A 1275 E shell was used, with an E interior and A+ block.
And here's the GTS.
#299 miniireland
miniireland
  • 175 posts
Posted 01 February 2018 - 12:56 PM
I need to get my Innocenti over to you Ben  :D
#300 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 February 2018 - 05:53 PM
More progress to report today.
I spent the morning de-greasing and masking up ready for the primer.
I also prepped up the new door and hung it ready.
Then on with the primer
Once that had baked, I brought the door back into the workshop and flatted the primer
And then sealed up the fold on the door skin
And then flatted the primer on the front end of the Mini
And then sealed the wing to scuttle seams
In the morning, ill flat the primer on the quarter panels and then paint it.
Ben
    Bing (1)
