1275Gt @ Mill Road Garage Isle Of Wight
721 replies to this topic
#211 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2017 - 08:41 PM
The cars in the bodyshop are crammed in like sardines today so not much has happened on the GT as i have had a T5 van to repair and an accident damaged Modus to do.
I did get bits and bobs done in between though.
The headlamps had stopped working again and so I quickly found that there was a break in the earth wire so a new one was run and that's now sorted.
The dashboard is now fitted which completes the interior
The inlet manifold water pipe has been removed as per John's request
The spark plugs and leads have been changed
After running the engine on Friday, i came in to a puddle of coolant on the floor this morning. The water pump has started leaking so a new one has been ordered and will be here tomorrow.
Here is the only photo i took today
Then green MG to the right is in for a quote for the front floors to be repaired and also has a broken needle in one of the carbs. The new needle will be fitted in the AM meaning that can be moved out making room to get on with the GT
#212 Carlos W
Carlos W
  • 10,114 posts
Posted 30 January 2017 - 08:44 PM
The pic shows how much tidier the pipe work looks
#213 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2017 - 08:50 PM
It does.
(shame the same can't be said for my workshop)  :rolleyes:
#214 Carlos W
Carlos W
  • 10,114 posts
Posted 30 January 2017 - 08:51 PM
It does.
No worse than my garage
#215 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 30 January 2017 - 08:57 PM
Ben
The engine bay looks a lot tidier (thanks) although the Mini does look like it's suffering from incontinence judging by the water on the floor. :-) :-)
#216 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2017 - 08:58 PM
It does.
As soon as i get all these cars out, i can have a good clean out. There is just no time to do it in between all the comings and goings and things are super busy at present
#217 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 January 2017 - 09:01 PM
Ben
That was the new puddle after i moved the car. i think it must have been slowly leaking all weekend.
Better for it to happen now than on the road though.
Ben
#218 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2017 - 07:06 PM
Annoyingly, the motor factor sent out the wrong water pump. The one i received had bypass outlet so is no good. The correct one will be here in the morning as they have had to order it.
I did get the old one off and the area cleaned up ready
I replaced the indicator flasher relay as the old one was being temperamental and this meant that i could screw in the dash cluster for the last time.
Whilst i was there, i gave the inside a clean up
Then after doing a few other jobs elsewhere, i came back to the Mini and started to flat and polish the paint work.
After one side was done, i applied the MINI 1275GT stripes to the side and screwed on the arch trims
More tomorrow
Ben
#219 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 31 January 2017 - 07:17 PM
Ben
The car is looking fabulous you have done such a good job and the GT stripes look great.
John
#220 wingnut
wingnut
  • 463 posts
Posted 31 January 2017 - 07:26 PM
John,you must be so chuffed how this is turning out.
What a great job you've done Ben
#221 Rocket.
Rocket.
  • 1,441 posts
Posted 31 January 2017 - 07:28 PM
Great job as always ben!
#222 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 31 January 2017 - 07:31 PM
I am so pleased with the way the GT is looking , the standard of work is so high, Ben has uncovered some horrors but has managed to either replace or fabricate panels to eliminate them all.
#223 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2017 - 07:33 PM
Thanks to all.
It is like a different car now and its so good to know that all the horrors are behind it and it's safe once more.
Ben
#224 Carlos W
Carlos W
  • 10,114 posts
Posted 31 January 2017 - 08:04 PM
Those door gaps look superb
#225 GraemeC
GraemeC
  • 7,437 posts
Posted 01 February 2017 - 08:01 AM
Looking great!
Why black wheel arch moulding only on the front?
