Pushrod lengths are easily changed by adding an extension piece to the bottom of the original pushrod. It costs alot of money to modify these if you have to pay someone as it is time consuming process. I made a set of 2 piece pushrods for MLMotorsport 4 years ago and these worked very well. The trick is to dry build your actual assembly then use an adjustable pushrod to work out the length that gives you the lift you need. Its worth an extra .015" or so extra lift on a nominal .500" lift setup. The most important point to note is to reduce the unsupported length of the pushrod to increase the stiffness as well as length.
I have a dedicated jig for this, although it sees little use and no one want to pay the going rate to use it. Med used to sell tubular pushrods that you simply machined to length. This would be cheaper than paying to have yours extended.
Ac
Thanks AC, yes I've done the geometry hundreds of times for Ford V8s, but there are thousands of pushrod options available for these. I was surprised there was so little mention of it in the Mini tuning sites. It's not so much the power that concerns me, it's more getting the angles correct for rocker to valve stem contact, centring on the valve stem tip correctly. Ford V8 valvesprings typically take at least 300-320lbs pressure with the valve closed, I don't know what the typical figures are for Minis. I suspect my sets of adjustable vernier pushrods and valve spring micrometer might not be the right size for these parts...
I'll have a look in the Vizard book to see what he advises.
Roger
edit - I see Mr Vizard suggests that unless the engine is for serious racing, the effort involved in obtaining precise valvetrain geometry is of 'questionable benefit'... maybe it's not as critical in a Mini!
Edited by rsk289, 04 November 2016 - 01:51 PM.
