Gap Between Bottom Of Door And And Door Step
Posted 03 November 2016 - 08:08 PM
The gap between the bottom of the door and the door step is about 3/8". If raise the door step to reduce the gap it is then too high to line up with the front fender lower edge and the rear quarter panel lower edge.
Is the 3/8" gap typical?
Your help is appreciated.
Bill
Posted 03 November 2016 - 08:56 PM
Posted 03 November 2016 - 10:30 PM
Thanks again,
Bill
Posted 03 November 2016 - 11:02 PM
Posted 03 November 2016 - 11:16 PM
Bill
Posted 04 November 2016 - 12:48 AM
Posted 04 November 2016 - 01:24 AM
Is it an original door and skin?? If it's been reskinned and not plug welded/spot welded before folding the skin around then things can move.
I'll take some pictures tomorrow and post them.
And before anyone asks; checking the door gap on the 1970 Mini would be pointless because those sills are a mess and I would not trust the measurement. I do however think the 70's doors are original. So the overall height measurement should be correct. I'll know more tomorrow.
Bill
Posted 04 November 2016 - 07:55 AM
If you trial fit the outer sill you can then check it sits on the floor / inner sill about right, that then gives you another set of points to check the door step ... The cars were almost hand built in the factory, so I don't think they were ever that perfect in the first place!
Edited by DomCr250, 04 November 2016 - 07:58 AM.
Posted 04 November 2016 - 05:21 PM
I have attached some pictures for your reference and took more measurements. But let me back up a little.
Before I cut out the existing inner sill and door step I welded in some bracing, keeping it parallel to the top edge of the existing inner sill. I recorded the dimension so I could install the new parts in that exact location. After temporarily installing the new inner sill on the left side I measured the opening from the lip under the roof to the top edge of the sill. I then compared that measurement to the right side and found them to be the same. So I believe I have the inner sill and door step at the correct location.
Today I measured the overall height of both doors on the 1978 car. They measure 37” in the middle. Then I measured both doors on the 1970 car. They both measure 36 ¼”. Go figure. The doors on the 78 have the door skin welded to the frame and appear to be original. The picture should confirm that for you guys.
I have pop-riveted everything in place and still have that gap so, I guess that gap is supposed to be there. If I don’t like it when everything is welded in place then I’ll add to the bottom of the door edge.
Thanks again for your help. Back to the garage I go.
Bill
Posted 04 November 2016 - 06:55 PM
Posted 04 November 2016 - 06:57 PM
Posted 04 November 2016 - 07:13 PM
I cannot post up the picture i want to Bill but as a guide using the swage line on the quarter panel to the lip, the measurement is 21"
Now use this as your guide to get the height of the step correct.
Posted 05 November 2016 - 12:43 AM
Now all I have to do is weld everything in place. The old spot welder is gonna get a workout.
Thanks for your help. I'll post more pictures later next week.
Bill
Posted 05 November 2016 - 09:54 AM
I get a local metal fabrication shop to make mine now. A hell of a lot cheaper than Heritage.
