Painting Prep Help
rust repair paint
3 replies to this topic
#1 Joshwaaa
Joshwaaa
  • 12 posts
Posted 01 November 2016 - 09:29 PM
Hello All
I have read a number of posts on painting prep ect but am a little bit unsure so would like some help please.
For the underside, wheel arches and engine bay I am going to strip back and apply POR 15 to protect then apply stone chip on the underside.
For the body work should I be using POR 15 for the base protector coat also ? If yes should this be sprayed or brushed on ?
Your help would be appreciated
Joshwaaa
#2 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 01 November 2016 - 10:37 PM
By all means use POR15 on the underside, but best to use a quality epoxy primmer on the
topside.
Feel free to PM me for more personal help if needed, not far from you!
Check out my thread ( Retirement Project Rover sprite)
#3 Daz1968
Daz1968
  • 2,058 posts
Posted 01 November 2016 - 10:41 PM
I used bilthamber epoxy mastic on underside and found it went on quite well
#4 bluedragon
bluedragon
  • 286 posts
Posted 02 November 2016 - 11:52 PM
I would not use POR-15 for visible body panel surfaces. It's very difficult to get a smooth (body panel quality) finish with POR-15, and it's extremely difficult to sand smooth like primer is meant to. And you'll have to do more panel prep work because POR-15 prefers a roughly finished surface to adhere to. These are all great for frames and the underside, or small rust-repaired sections, but I'd shudder to think about doing a whole body.
I agree that a quality epoxy primer would be the best choice. It will give nearly the same moisture-resistant properties, and the other properties of POR-15 are largely irrelevant for a clean, rust free external body panel surface.
Dave
Also tagged with one or more of these keywords: rust repair, paint
