I purchased a new speedo drive cable and tried to install it into the pinion gear on gearbox. It refused to go in. I removed the pinion gear and compared it to the end of the drive cable. The female opening on the pinion is too small compared to the end of the drive cable.
I ordered another cable from MiniSpares. Same result. The pinion gear does not appear to be damaged. Both cable ends are tapered and smooth. I realize the two should be a tight fit, but this seems wrong.
Any ideas?
Thanks,
Joe
