Hi all. Do you HAVE to use exhaust jointing paste ? If the two parts of the exhaust sleeve together quite nicely and are clamped, is this enough ?
Exhaust Jointing Paste ?
scooby doo
, Oct 29 2016 01:38 PM
5 replies to this topic
Posted 29 October 2016 - 01:38 PM
Posted 29 October 2016 - 01:42 PM
There's a lot of pressure on the joint and if you don't you'll get some blow by no matter how tight you think you've sealed it. If you have a lambda fitted you'll definitely need to seal it otherwise it will affect the reading.
Posted 29 October 2016 - 01:44 PM
I use a high temperature exhaust silicone to allow for some flexing in the joint. Paste cracks when the engine rocks and moves the joint. Whichever seal you use, you need to leave it for 24 hours before starting the engine. This stops the sealant from being blown out of the joint before it has time to set.
Edited by Northernpower, 29 October 2016 - 03:22 PM.
Posted 29 October 2016 - 04:00 PM
ok thanks for that good advice..exhaust silicon it is then !!!
Posted 29 October 2016 - 04:05 PM
I've never left it, in fact once on i get the exhaust nice and warm to allow the paste to cure.
If the cars not going to be started I use a heat gun on the localised area to cure the paste.
Posted 29 October 2016 - 05:10 PM
Whatever works for you, I don't use paste on a sleeve joint where there's a chance of movement, I find silicone works better for me; it doesn't crack and doesn't need heat to cure it.I've never left it, in fact once on i get the exhaust nice and warm to allow the paste to cure.
