Loose Indicator Stalks
8 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 20 October 2016 - 06:02 PM
Hi;
Both stalks on my steering column are quite loose e.g. lots of play.
Is this normal - will it pass an MOT - can they be tightened?
#2 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 20 October 2016 - 07:53 PM
I had this and the Mini did pass it's MOT but they were all working properly just a bit loose. What you will probably find is the plastic clap has snapped due to age and fatigue I glued mine but added a metal strengthening piece to the outside of the clap to reinforce the glue joint and it is now nice and tight again
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 20 October 2016 - 08:25 PM
as above
remove covers and look see there is a pozi screw that needs tightening or clamp is snapped..
#4 tiger99
tiger99
  • 8,584 posts
Posted 20 October 2016 - 09:49 PM
Something of which you should be aware. Some years ago someone repaired his stalk mountings with a self tapper. Nothing wrong with that, except that the hardened point of the screw, unknown to him, was contacting the inner column, which caused a small groove to form. The resulting stress raiser caused a fatigue fracture of the column, which happened at speed, and he was killed.
So depending on what exactly you are doing, it may be necessary to avoid pointed self tappers. There is always another way, or several. If they are not pointing towards the column, but tangential, they are of course ok.
Actually there is a general point there, always watch where the business end of screws are going. We all know of, and many of us (yes, me too) have done it, locking our flywheel ring gear by using the wrong slave cylinder bolts, for instance. Or bottoming a bolt and jacking a huge chunk of metal out of our valuable engine block...
This is all about developing engineering instinct and a sharp pair of eyes, which come with experience. I am by no means suggesting that anyone is stupid, just identifying a potentially fatal trap to avoid. The guy who killed himself was actually fairly accomplished at engine tuning and such like, yet he was caught out, which is why I mention it.
#5 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 October 2016 - 01:34 PM
Thanks fellas.
I'll take the steering column cover off and take a looksee. No pointy self tappers :-0
#6 tiger99
tiger99
  • 8,584 posts
Posted 23 October 2016 - 09:28 PM
Good!
#7 1984mini25
1984mini25
  • 8,784 posts
Posted 02 November 2016 - 04:22 PM
Thanks fellas.
But you can fix them with 2 self tappers and a hose clip...
http://www.theminifo...o-20/?p=3380909
#8 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 02 November 2016 - 08:34 PM
Thanks fellas.
Nice repair.
What length self tappers did you use? I could try this with it still fitted as I don't have a socket large enough for the steering wheel (yet)?
#9 1984mini25
1984mini25
  • 8,784 posts
Posted 02 November 2016 - 09:47 PM
Thanks fellas.
Nice repair.
Not too sure to be honest, as I have a jar of mixed screws for odd jobs and just used whatever were suitable. Although I did have to file the points off them, as they poked though just enough to stop it sliding onto the outer column.
The steering wheel nut is 1" 5/16 or about 34mm.
