Well it was a mamouth task but I have just managed to change the front brake hoses Left and Right. I am now trying to bleed the brakes but I am having some trouble in doing so.
The car has been off the road for several years whilst I have been restoring it. The Rear Subframe (and brakes) were removed and all new rear brake lines fitted.
I am using a Vizibleed one person bleed kit and started with the rear Left Hand side. After fixing a leaking hose on the rear right, I seem to have been able to bleed the back Left and the the Right, old brake fluid was eventually expelled and then new clean stuff came through. I could not see the bottle whilst pumping the brakes but the plastic line on inspection was full of clear fluid, but air may have crept back up.
But when I tried the front left I cannot clear the air, I can see the bottle and can see the air moving in the tube but I cannot seem to pump the brake pedal fast enough to move the air down the tube.
I think the problem may be the Vizi Bleed kit and the difference between my front and rear Brake Cylinders. The rear are new and the bleed nipples are smaller. The rubber pipe fits completely over the bleed nipples on the rear but on the front it only goes over the end of the nipple. I think maybe air is leaking into the bleed tube?
I have used a bottle of Dot 4 already so need to get some more :-(
Any advice in case I am doing this wrong would be appreciated.
