Hi all
Driveshafts out.
There is about 0.5 mm play at the shaft in the differential housing on drivers side where the pot joint attaches. I was about to remove the diff housing a re gasket and pop on a new seal.
But is this pointless in solving leak problem? Are my bushes in the differential worn? How much play is acceptable on the inner drive shaft?
Can I change these myself? What part do I need? Engine is still in the car.
Kaz
With the pots off and about 0.5 mm play in the output shafts of the diff, it does show some wear, but it should be quite OK.
You can of course remove the diff side covers and re-bush and ream those to size, or as greenwheels linked up, buy new covers with bushes fitted.
Mini Spares have the same item, but a bit cheaper http://minispares.co...|Back to search
BUT, before changing these covers and / or re-bushing them, how much play / wear do these bushes have? Ideally you need to remove the cover and fit the pot joint in to it to check, but you can get a good idea while on the car. With the seals still fitted, you need to wobble the joint and see if the seal lips are still making good contact with the joint.
If you do remove them to check, use a feeler gauge (tapered end types are best for this), in at lease 3 places. Anymore than 0.012" and they are best replaced.
Edited by Moke Spider, 27 September 2016 - 08:00 PM.
