I'm currently rebuilding my 998 engine and I would like to Gas-Flow the head. What is involved in Gas-Flowing the head? I know that reducing the 'V' in the chamber and reshaping the throats around the valves would make an improvement as well skimming the head to get the compression ratio up. Is there anything else that would make an improvement?
The head is a completely standard and un-modified CAM4810 head. The engine will be running a Kent 256 cam, Twin HS2 carbs and Maniflow Freeflow manifold and Maniflow 1.75 inch single silencer stainless steel exhaust.
I won't be doing the work myself as I don't have the equipment or skill so will be getting a machine shop to do the work.
Thank you,
James C.
