#31
Posted 03 February 2017 - 11:09 PM
#32
Posted 03 February 2017 - 11:19 PM
Making good progress. Can I ask what you used to clean up the inner wing?
Normally I use a mixture of a DA sander, knotted wire wheels on the grinder, 2" sanding discs for those hard to reach bits and those silicone carbide paint removal discs you see in Halfords.
Before all that though, I had to scrape off all the old underseal which was not a pleasant job.
#33
Posted 05 February 2017 - 07:08 PM
Well didn't get anymore done on the mini today but did manage to get my garage ceiling plaster boarded, which not only used up some old plaster board I had taking up space but also makes the garage much lighter.
I have a 10k run to do in two months so the mini might have to fit in around runs, but to be honest I'd rather be welding than running
#34
Posted 12 February 2017 - 10:11 PM
So with the scuttle corner repair done I decided to attack one area I really wasn't looking forward to, the front bulkhead.
First I scraped off the what sealant I could get to with a scraper.
not pretty, so I dug a little deeper with the wire wheel
More excavation later
Edited by nicnoo, 12 February 2017 - 10:19 PM.
#35
Posted 18 February 2017 - 10:13 AM
Those what know me will know that i'm a firm beleiver in the ying and yang theory, for every action there is an equal and opposite reaction etc etc.
Today my wife rang me to tell me a large package had arrived
I'm always jealous when people post photo's of large minispares orders. If you ever need a better reason for subscribing to the mini forum. £5 for the subscription, £20 saved off my order ........
And Then this happened...............................................
#36
Posted 18 February 2017 - 02:47 PM
What happened?
#37
Posted 19 February 2017 - 09:54 PM
Driving home and it just cut out on me, tried what I could at the side of the road (leads, cap, coil etc.) but no good. RAC man made me laugh he had no idea how an "old" engine like mine actually worked, except to diagnose there was no spark. anyway did a little investigation myself and found a fault with the 12v feed to the coil. so for the time being I have bypassed this feed with a piece of scrap wire until I can make a more permanent fix.
#38
Posted 19 February 2017 - 10:53 PM
Lot of pitting on that crossmember, time to change bits of it.
#39
Posted 21 February 2017 - 09:53 AM
This is one area I didn't think would be too bad given the natural rust prevention coating (oil) that was all over it. I think I'll have to dig out the grit blaster and get right in to the corners.
#40
Posted 22 February 2017 - 12:42 PM
Decided to have a go at tidying the workshop up a bit but got completely side tracked and instead decided to strip down my swing arms ready to mount on my new rear subframe (that I don't know about because it's a birthday present for next week)
And this is what I was left with ...........................
Also got the last bit of welding done on the A-post to inner wing so I was able to splash a bit of primer on for protection whilst I attack the crusty cross member.
Edited by nicnoo, 22 February 2017 - 08:53 PM.
#42
Posted 15 March 2017 - 10:36 PM
Quick update, so after a few days/weeks of scraping, sanding, grinding, blasting, swearing I finally have the bulk head in a state I was happy with so everything was cleaned up and given a coat of etch primer.
Also spent some of my birthday money and received this in the post today
Hoping to get some more done at the weekend
#43
Posted 17 March 2017 - 01:08 PM
nice repairs! And love the hand made parts.
#44
Posted 20 March 2017 - 09:42 PM
Thanks Dom
#45
Posted 23 March 2017 - 10:22 PM
So my intention was to work on only the body shell and not get distracted by mechanical bits and bobs, However........................................ A shiny new rear subframe has been begging for some attention.
first job was to start refurbing the swing arms, backplates, hubs, etc. which I will photograph later.
I also stripped the black E-coat off the new subframe ready for a coat of etch primer.
and this happened....................
I know it's never a good idea to leave bare metal exposed but this was literally overnight, compare this with the scuttle panel that I stripped about six weeks ago
is this an indication of the quality of steel they're using for the pattern subframes ? who knows, Ill scrub it all back before I give it a blow over with the primer.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
