Cooper S Wheels Vs Reverse Rims
12 replies to this topic
#1 mkw
mkw
  • 1,003 posts
Posted 22 September 2016 - 10:24 AM
Hello,
I'm getting a little confused about which are which.
I currently have 10" alloys on a S brake set up with no arches but i'm wanting to swap to steels with the chrome caps.
If i get the reverse rims am i right in thinking they will stick out from the body work? If i get standard S rims they should fit under and keep everyone happy?
Could someone post photos of both for me and show me the difference? I've done a search but people seem to be confused themselves when they say Cooper S wheels.
Thanks,
Michael
#2 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 22 September 2016 - 06:35 PM
Hi
I'm not on a PC to post pictures, but at the top of my ownership thread are some pictures of the Cooper S steels (not reverse but with brake discs) sold by MiniSport.
The reverse steel wheels will sit outside of the wheel arch if you have brake discs. And will sit flush if you have drums all round.
http://www.theminifo...d/#entry3410154
James
#3 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 22 September 2016 - 07:10 PM
Not the best picture but here's some reverse rims, arch less, on 145 tyres, cooper s brakes. The sidewalk stuck out like 5mm if that, and you can easily get away with being arch less.
#4 Will16
Will16
  • 1,090 posts
Posted 22 September 2016 - 07:12 PM
Here's a google image picture of regular Cooper S rims. Not sure on the brakes, but they are well under the arches
10E1CFB5-1DCB-41D3-85F2-8CAA70A85A7E_zps
#5 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 23 September 2016 - 07:51 AM
There are two different Cooper S wheel sizes:
3.5 x 10 - LP882
4.5 x 10 - LP883
Both of these had the nine circular holes around the wheel.
The reverse offset wheels (LP918) are the same basic wheels as the 4.5 x 10 Cooper S wheels but had the inner section welded in backwards. They stick out about an inch further than the standard Cooper S wheels.
#6 Cooperman
  • 23,276 posts
Posted 23 September 2016 - 07:19 PM
Reverse rim 4.5" wheels were originally made so that a 4.5" wheel could be fitted to 850 and 998 Cooper models without the need for spacers
#7 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 23 September 2016 - 08:59 PM
Dunlop 4.5" reverse rims with AO32Rs
#8 mkw
mkw
  • 1,003 posts
Posted 23 September 2016 - 09:47 PM
So this is running drums? It looks brilliant!
#9 mkw
mkw
  • 1,003 posts
Posted 23 September 2016 - 09:49 PM
Hi
James
Are you able to get hubs to fit these wheels?
#10 Cooperman
  • 23,276 posts
Posted 23 September 2016 - 11:20 PM
The 'S' normal 10" wheels will only fit onto 'S' hubs and drums. The reverse 4.5" wheels will fit drum brakes and 997/998 Cooper 7" discs and hubs, but if fitted to 'S' hubs & drums will stick out and arch extensions will be needed.
Edited by Cooperman, 23 September 2016 - 11:21 PM.
#11 Ace Alex
Ace Alex
  • 330 posts
Posted 24 September 2016 - 08:19 AM
Forgot to mention that MKW, it has discs fitted.
Found another photo...
Edited by Ace Alex, 24 September 2016 - 08:24 AM.
#12 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 24 September 2016 - 08:38 AM
Hi
James
They have the small tabs so yes. You can always give them a quick call.
https://www.minispor...abs_description
James
#13 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 11 October 2016 - 12:14 PM
God I love that van!
