What Does The Fuel Trap Do?
3 replies to this topic
#1 Austin se7en
Austin se7en
  • 10 posts
Posted 19 September 2016 - 09:28 PM
My fuel trap blows through easily but just wondered what it is supposed to do so I know if it is actually doing it's job.
#2 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 20 September 2016 - 08:15 AM
The charcoal canister? It's an fuel vapour trap from the tanks as its pressurised, it then feeds it into the engine via an ecu controlled valve
#3 edkirk30
edkirk30
  • 42 posts
Posted 21 September 2016 - 05:16 PM
Or are you talking about the fuel trap before the ECU MAP map sensor? This is to limit fuel reaching the MAP sensor and effecting its operation. If it's cracked it will effect the vacuum and will definetly need replacing.
I don't know if it gets 'full' and I don't know the mechanism it uses to trap the fuel, but many recommend replacing them periodically as a service part. If the vacuum line from the fuel trap to the MAP sensor has any residue I guess that might be a sign it's not doing it's job very well.
#4 FlyingScot
FlyingScot
  • 2,664 posts
Posted 25 September 2016 - 08:03 PM
What he said ^^^^
Service item designed to stop fuel vapour and general crud getting into the MAP sensor which is soldered to the circuit board on an SPi
No special internals just an air space and gravity
FS
Edited by FlyingScot, 25 September 2016 - 08:04 PM.
