Spark Plug 1 And 4 Is Black...
Best Answer harritz3257 , 10 April 2017 - 07:51 PM
Problem was a few things.
Bad spark plugs, lambda sensor and the headgasket had failed between cylinder 2 and 3..
Changed the gasket, plugs and sensor along with a new stage 3 head and it runs smooth again :)
Go to the full post
11 replies to this topic
#1 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 17 September 2016 - 05:37 PM
Hello,
So lately my MPI's (1997) idle has started to sound weird.. Its like its misfiring..
My "Mini Tech Level" was quite low at this point, so i just replaced the spark plugs and thought the previous owner had not changed them..
2 months later and im having the same problem. Today i pulled the park plugs and here's the weird thing.. Cylinder 1 and 4 is all black, but cylinder 2 and 3 are the correct color.
Whats bugging me, is that the injector for cylinder 1 and 2 is the same, so how come the spark plugs aren't the same??
Hopefully im not the first one to have this problem.
Regards Michael
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 18 September 2016 - 03:15 PM
Normally it's the other way round lol
#3 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 23 September 2016 - 08:41 AM
I know :)
I've borrowed a cleaning machine that cleans the intake (car needs to be turned on in idle for 2 hours, while the machine sprays something into the air intake).
Hopefully this will fix the problem..
/Michael
#4 Minimpi44310
Minimpi44310
  • 11 posts
Posted 07 November 2016 - 07:20 AM
Hi,
is your problem fix?
My mini MPI 1999 same problem
I changed the TDC Sensor and now it's good.
You can try to clean the sensor, (filing snap*, black dust*) this is free free !
Regards
Claude
* limaille et * suie
#5 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 26 November 2016 - 07:55 PM
HI Claude,
Im affraid not.. well i've bought and fittet a new cylinder head, but i havnt had the chance to fire it up yet.
Got a link for the TDC sensor? and maby a picture. (I have no ideer where to find it  :D )
Regards Michael
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 29 November 2016 - 09:41 PM
It's above the starter on lhs (as you look under bonnet) with a blue connector.
FS
#7 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 30 November 2016 - 10:24 AM
sounds like it could be weak spark, check the leads, the spark plug gaps and the coil pack, check your valve clearances as well
#8 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 01 December 2016 - 07:25 AM
Thanks FlyingScot & Fast Ivan, i'll give it all a try.!
#9 thelittlecarcompany
thelittlecarcompany
  • 33 posts
Posted 07 January 2017 - 10:30 PM
Did you find a cure to your problem? Is it running rough or just on idle? I think I might have the same problem!
#10 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 18 March 2017 - 03:41 PM
Sorry about the late reply.
Its still in storage, but i'll give it a look in a few weeks when the snow is gone.
Please do update the topic, if you find a solution.
My symptoms are rough idle and sometimes a cylinder isnt fyring as it should. When i get past 1500rpm I cant hear it..
Also my mechanic told me that i should have a look at the intake manifold, it could be filled with carbon.
/Michael
#11 cian
cian
  • 869 posts
Posted 18 March 2017 - 03:49 PM
Idle control valve, spark plugs, ht leads, coil pack
#12 harritz3257
harritz3257
    Just On Tickover
  • 6 posts
Posted 10 April 2017 - 07:51 PM   Best Answer
