Fitting A Classic 80Mm Smiths Tachometer
10 replies to this topic
#1 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 16 September 2016 - 11:35 AM
Hi all,
I am trying to fit an old Smiths 80mm Tachometer and need some assistance with the wiring please.
Here is a picture of the back of the gauge. The engine is a late type 1275 with electronic ignition.
Many thanks,
Tim
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 16 September 2016 - 11:43 AM
Got a picture of the front to see if its compatible with electronic ignition? I think the code is at the bottom of the dial ..
#3 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 16 September 2016 - 12:25 PM
The code says RV1003/00
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 16 September 2016 - 04:23 PM
Looks like it uses an induction loop? Mine works with a 65D distributor.
#5 carbon
carbon
  • 2,590 posts
Posted 16 September 2016 - 05:03 PM
See Doug's post in this thread: http://www.theminifo...hs-rev-counter/
You have the RV1 with induction loop sensor
#6 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 27 September 2016 - 06:28 PM
Hi all,
Many thanks,
Tim
Messaged you
#7 smudger068
smudger068
  • 344 posts
Posted 28 September 2016 - 09:13 AM
I thought electronic ignition and RVI don't mix? Don't you need an RVC?
#8 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 04 January 2017 - 12:20 PM
After installing and going for a drive I found that the engine will not rev. It hesitates at anything over 3,000 rpm. After disconnecting the wire from the coil everything was ok again. Assuming that This does mean that the RC1 gauge I have is not compatible with electronic ignition.
Would you all recommend that I try and find a RCV gauge instead? Do they make them in the same sort of style?
#9 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 04 January 2017 - 05:20 PM
As we can't see the dial it's had to say but yes, Smiths do them in RVC mode. http://www.smiths-in...s.co.uk/classic
#10 mini-geek
mini-geek
  • 1,169 posts
Posted 04 January 2017 - 05:53 PM
You can get a clever little curcit board to convert them for about £40
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 January 2017 - 10:58 PM
Bare in mind those old 8omm rev counters are getting on a bit, I have had several MGBs in where the rev counter bounce has to be seen to be believed to the point when on/off the throttle there almost unusable, They were not that well damped when new, If I was you I would get one of the newer Smiths but they are expensive, but there are others you could use for around £30.
Be aware of the ones that come of of the later MPi cars with coil packs, they read double the rpm in a distributor driven engine. there is a mod but again its cost vs time vs skill
