Hi All,
Last time I went on a Trackday (1st time in this mini) I had a bit of a scary moment where blue smoke appeared inside the car and a brief trail behind me, when I checked it was oil that had come out of the Clutch housing breather and had go onto the manifold, hence the smoke.
I now have a last minute Trackday booked for next Tuesday so need to fix this ASAP.
I think the correct fix is to fir an oil catcher tank, but don't think I have enough time to do that.
My other 2 alternatives are:
1. Connect it directly to the Rocker cover, will have to cut a hole in the rocker cover to fix a pipe to, then fix a flexable pipe from that to the Clutch housing breather.
2. fit a canister type breather I have and connect that to a pipe I have coming from the timing cover breather.
No 2. is the easiest option but I don't want oil going into the timing cover do I.
Anyone got any other ideas?
Not totally sure why this is happening apart from Hi speed cornering, but might have that completely wrong.
