My Classic Mini Cad Work
37 replies to this topic
#31 grizzler73
grizzler73
  • 300 posts
Posted 22 September 2016 - 06:40 PM
I have started to model my GTM chassis up in Solidworks, still got the front and rear sections to do which is the tricky bit! Really need a model of a front subframe nut can't find one anywhere, guess I will have to model it myself, a daunting prospect!
#32 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 24 September 2016 - 05:10 PM
For fasteners I use Traceparts. LOADS of models on there, just have to know what to search for.
Are you using sheet metal in Solidworks for that or extrudes?
#33 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 24 September 2016 - 09:52 PM
I found the sheet metal feature worked really well for the few parts I drew up.
#34 Midas Mk1
Midas Mk1
  • 5,776 posts
  • Local Club: S.U.N.M.C
Posted 24 September 2016 - 10:19 PM
Looking good, I too have progressed doing CAD of my Minis & Midas.
For my 4th (final) year at Uni last year, I designed and developed a kit car , and created a 1:5 scale model entirely 3d printed by myself using the CAD model I created.
Used solidworks for all the chassis, mechanical components, and Alias & 3ds for the body.
Good luck on your work, I know the amount of time it takes, and appreciate the effort gone into the small parts to make them accurate,  think I spent about 4 weeks solid day and night doing my CAD aha!
(5 months day and night 3d printing at home too >_< :lol: )
Edited by Midas Mk1, 24 September 2016 - 10:20 PM.
#35 grizzler73
grizzler73
  • 300 posts
Posted 25 September 2016 - 09:02 PM
I have extruded everything as I am unsure how it all goes together at the moment. I am mainly doing the model for stress analysis as the footwell area of the GTM is renowned for twisting so I want to add in some stiffening and see how it helps without messing about with the actual chassis if that makes sense, then hopefully I can get it right from the off.In my post it should have read subframe BUT not nut, stupid fat fingers! I don't usually bother with nuts and bolts on larger parts and assemblies as it slows everything down but thanks for the tip.
#36 Mini 360
Mini 360
  • 4,933 posts
Posted 26 September 2016 - 07:29 AM
Finally got the drive flange/hub assembly off the car over the weekend.  Cleaned a few bits up so i could take them to work to model up over lunchtime.  This model is going to be detailed!!!
0C547F96-EEA1-45E2-AC20-4FEF5145FBF3_zps
#37 Mini 360
Mini 360
  • 4,933 posts
Posted 26 September 2016 - 12:32 PM
Lunch over and heres the products
Drive flange modelled accurately.  Ended up starting from scratch as m memory wasn't as good as I thought it was :lol:
Accurate%20drive%20flange%20assy_zpsr06u
Accurate%20drive%20flange%20assy%20rear_
With the bevelled washer in place
Accurate%20drive%20flange%20assy%20with%
Also modelled up the ball joint and cup.
Modelled up a couple of the bearings for the front hub but no screenshots of them as well...they are just rings and rather boring as a result :lol:
#38 grizzler73
grizzler73
  • 300 posts
Posted 26 September 2016 - 09:50 PM
Made some good progress on my model, got a couple of panels to work out at the front still though.
    Bing (1)
