Help No Oil Pressure After Rebuild
76 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 04 September 2016 - 08:43 PM
Hi all, I have just done my first turn over of my rebuild and my oil pressure gauge isn't moving whilst cranking it over. Any ideas on what to do? Im feeling pretty demoralised at the moment.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 04 September 2016 - 08:44 PM
Did you prime the pump?
All oil gallery plugs refitted?
Did you fill the filter before fitting?
#3 Alex_B
Alex_B
  • 4,573 posts
Posted 04 September 2016 - 08:46 PM
O-ring fitted between block and box?
How long have you been cranking for ?
#4 nicklouse
  • 18,577 posts
Posted 04 September 2016 - 08:47 PM
Has the guage ever worked? If yes what is different.
#5 Midas Mk1
Midas Mk1
  • 5,775 posts
  • Local Club: S.U.N.M.C
Backfill the oil pump and try again (oil down the oil transfer pipe from the top of the block, pushing the car backwards in gear for the oil pump to suck it through)
#6 blacktulip
blacktulip
  • 6,224 posts
Posted 04 September 2016 - 08:54 PM
Pump primed, gallery plugs fitted, o ring fitted. I didn't fill the filter. Is that where I might have gone wrong? I cranked it at least 30 times.
The gauge worked before. However I did get a second hand oil feed pip from the block. I wonder if it was blocked. Is there a manual test I can do?
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 04 September 2016 - 08:55 PM
Does the light go off?
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 04 September 2016 - 08:59 PM
I'm sure it's never had a light for oil pressure.
#9 Spider
  • 14,840 posts
Posted 04 September 2016 - 09:01 PM
Loosen it a bit and see if some oil comes out.
Sometimes they do need a good cranking, up to a few minutes, though if everythings right and the Oil Pump is primed (noted you've done that) it usually takes 30 - 60 seconds.
#10 Dusky
Dusky
  • 5,322 posts
Posted 04 September 2016 - 09:04 PM
Think it takes quite long on the starter to fill the filter. Id take the filter kff and see if its full already/fill it
#11 blacktulip
blacktulip
  • 6,224 posts
Posted 04 September 2016 - 09:12 PM
If there is oil in the filter is that a sign the pump is working as it should?
#12 nicklouse
  • 18,577 posts
Posted 04 September 2016 - 09:44 PM
Disconnect it and crank once does everything in front get covered with oil?
Yes then you might have a blocked pipe.
Disconnect from guage. Crank engine does the inside of the car get covered with oil? No then you have a blocked pipe.
Note take care and catch any oil that may be ejrpected under pressure from your orifices.
#13 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
To help mine get oil pressure on its first run I turned it over with the filter loose / off.
Put a tray under it though
#14 nicklouse
  • 18,577 posts
Posted 04 September 2016 - 09:52 PM
IT is also good to have a screw in pressure guage at times like this so you know you are not going mad.
Like I almost was before.
https://youtu.be/XXWt8915ZdI
See pressure guage at the startish.
#15 morley
morley
  • 903 posts
Posted 05 September 2016 - 06:41 AM
Any big oil leaks?
