Distributor Drive Shaft Doesnt Fit New Block?
Posted 27 August 2016 - 05:20 PM
Pics here
https://imgur.com/gallery/32KSI
Posted 27 August 2016 - 05:32 PM
Posted 27 August 2016 - 05:43 PM
You need to get the correct distributor to fit your block. You can get a points dizzy for either type.
Posted 27 August 2016 - 05:48 PM
Posted 27 August 2016 - 07:09 PM
All of these are mentioned in the Haynes manual.
But in this area you are looking the A has two bolts for clamping the dizzy while the A+ has one and a clamping fork.
Posted 27 August 2016 - 09:44 PM
Posted 28 August 2016 - 08:17 AM
why not use the one with the black module? If the loom is missing, im sure you can buy it from minispares
http://minispares.co...01.aspx|Back to
Or you can wire it using small terminals, if 3 pins, then the middle one isnt used. One negative and one positive, there will be guides to which is which on the interwebnet.
Posted 28 August 2016 - 08:43 AM
Apologise here in advance, but I felt I should bring these recent threads to your attention regard fitting 'any old distributor' to an engine, you might already be on top of it, I'm not sure. They are all on the same car, just separated in to 3 threads;-
http://www.theminifo...n-full-advance/
http://www.theminifo...timing-scatter/
http://www.theminifo...izzy-now-fixed/
Also FYI, you can fit an A dissy to an A+ Engine and viki-verka. All you need do is note down the orientation of the drive dog to the rotor button, then drift the pin out of the dog, swap, check the orientation as per your sketch / notes and re-fit the pin. The other point to be aware of is that the A Distributor shaft is about 0.020" longer than the A+ one, so you'll need to grind a lick off the length of it. The other thing is if fitting A+ Dissy to an A Block, you'll need to be creative for a clamp. As a matter of course on all A Engines I do these days, I weld a short piece to the Dissy collar (that goes on the block), drill & tap 3/8" UNF and use the A+ Clamp. Easy, takes about 5 minutes and is a much better clamp.
Edited by Moke Spider, 28 August 2016 - 08:43 AM.
