65D Lucas Electronic Dizzy Now Fixed
12 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 27 August 2016 - 01:45 PM
picked up 65d lucas electronic dizzy this morning from AC
it was miles out
after AC got his hands on it the car now response a lot better
and revs nicer when blipping the throttle
we need to pay more attention to out dizzys and get them checked
mine was off a low compression sprite yet it was a 65d
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 27 August 2016 - 03:58 PM
Glad you like it racingbob. The point is people need to do what you did, measure the curve they actually have rather than go by what you think you should have. Also to add just because something is new does not mean it right. You check to make sure its right.
Ac
#3 nicklouse
  • 18,583 posts
Posted 27 August 2016 - 07:20 PM
But why did you presume it was correct as it was a 65d?
The vac advance can normally has its caracture stamped on it and the bob weights say what advance they give the only fun bit is the springs which I have forgotten every thing about ....
But is is good to know there are still people out there who know their onions.
#4 Spider
  • 14,849 posts
Posted 27 August 2016 - 09:51 PM
Glad you've had it done and done right.
Funny now that it is right how it is better :D
Ac
http://www.theminifo...d-distributors/
#5 racingbob
racingbob
  • 3,061 posts
Posted 28 August 2016 - 11:37 AM
yes took it for good spin this morning and yes so much better
it now pulls from 2000 in top with slight incline
money well spent
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 28 August 2016 - 11:43 AM
Cracking result.
Enjoy
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 28 August 2016 - 02:00 PM
The dizzy is one of those items that can give you some of the biggest increase in efficiency and drivability for a very modest outlay. No matter what you bolt onto your engine it simply won't perform without the ignition timing being correct. Even standard engines can benefit. It really is an overlooked area for alot of owners.
Ac
#8 nicklouse
  • 18,583 posts
Posted 28 August 2016 - 03:49 PM
Ac
I first started looking into this over 20 years ago when we fitted a PoleStar ignition system. When I get around to it I will be fitting a mappable ignition system along with a lambda sensor and maybe a throttle Pot.
#9 Spider
  • 14,849 posts
Posted 28 August 2016 - 07:40 PM
Ac
I feel much the same can be said for the fueling side of things too.
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 28 August 2016 - 10:10 PM
Absolutely!
Ac
#11 nicklouse
  • 18,583 posts
Posted 28 August 2016 - 10:14 PM
Well there is the believe that as it was fitted as standard it can't be that good.
While there is very little wrong with the SU.
#12 racingbob
racingbob
  • 3,061 posts
Posted 04 September 2016 - 03:57 PM
been 2 weeks now since having AC correct my dizzy
the car is so much more exciting to drive
big smile on my face every time i go out
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 04 September 2016 - 06:27 PM
That's what its all about, small changes big improvements!
Ac
