Hi all, I've got a leak coming from an area which i believe is the oil gauge, from the front its at the left of the engine, on the head. I'm thinking of taking it out, any precautions, i.e. is there going to be oil everywhere or? only just started getting things ready and its my first project!
Oil Pressure Gauge Leak
Posted 23 August 2016 - 07:54 AM
Posted 23 August 2016 - 08:01 AM
Shouldn't be any oil lost as long as engine isn't running
Posted 23 August 2016 - 08:02 AM
the oil take off is on the block not the head.
pictures?
Posted 23 August 2016 - 08:06 AM
Posted 26 August 2016 - 08:42 AM
Posted 26 August 2016 - 08:47 AM
work out pictures.
post to a host and link.
so it is leaking from the group of connections and not the head?
Posted 26 August 2016 - 08:54 AM
Why the photos have posted upside down I have no idea!
Edited by Lewbo, 26 August 2016 - 08:56 AM.
Posted 26 August 2016 - 02:33 PM
A little bit of oil may weep from there if you remove it, but not loads. (obviously don't run the car without something like the pressure switch in the hole)
It may be that the threads on that connector are wrong.
Are there 3 things plumbed into it?? Pressure gauge, pressure sender and?????
For reference, that's the block, not the head.
Clean it all up and see if you can find the source of the leak
Posted 26 August 2016 - 04:59 PM
Like Carlos says, there's a lot of plumbing there...
The most I have ever used is a 't' piece with one sender and one pipe to the gauge.
I'm also curious to know what else is connected?
Posted 26 August 2016 - 05:06 PM
Posted 27 August 2016 - 08:52 AM
I'll have another look later on and figure out what goes where, only just got it, just getting to grips with basic mechanics and repairs!
Edited by Lewbo, 27 August 2016 - 08:55 AM.
Posted 27 August 2016 - 09:25 AM
Just to check, None of those things connected will reset?
What do you mean by re-set?
There wont be any need to calibrate anything after removing them and putting them back
Posted 27 August 2016 - 11:19 AM
My guess is 2 x oil pressure gauge (1 x mech & 1 x elec) & oil temp.
Very poor place to measure oil temp as there is no flow most of the reading will come from conducted heat from the block.
But three connections. Guage,low pressure warning switch ,and as you suggest a temp sender.(but threads would be a bit small) so maybe two gauges.
Posted 27 August 2016 - 04:49 PM
I'll have another look later on and figure out what goes where, only just got it, just getting to grips with basic mechanics and repairs!What do you mean by re-set?
Most resetting my Mini requires is done by judicious application of a hammer
Posted 27 August 2016 - 09:32 PM
The leak may be caused by different threads. Some items have a taper thread and require PTFE tape to make the seal, others a plain thread, possibly 3/8" UNF, and require a copper washer to make the seal against a flat face. Both types are commonly found on oil pressure switches and gauges.
Unscrew them all, determine the type of thread on each, and apply the appropriate type of seal. Neither type is prone to leaking when done properly.
