Anyone put this on their mini? Ordered a pair and I'm just wondering if they're any good & work.
http://www.minispare...g-classic-mini/
Posted 21 August 2016 - 10:06 PM
Posted 22 August 2016 - 12:34 AM
Its a start, but no way near enough if you want a real silent Mini.
Fitting a set of aluminium inner wings will make a huge difference.
Not only will they make it hard for the dredded tinworm, to eat your front, but they also remove tyre / road noise BIG TIME.
Edited by JC T ONE, 22 August 2016 - 11:03 AM.
Posted 22 August 2016 - 01:21 AM
Edited by Magneto, 22 August 2016 - 01:22 AM.
Posted 22 August 2016 - 02:58 PM
Fitting sound deadening to the underbonnet isn't IMHO not going to make a huge difference. You will abosrb some sound, but most of that sound is being transmitted from the engine bay into the air above the bonnet, not inside the cabin.
Posted 22 August 2016 - 05:44 PM
http://www.lokari.de...KF-0173-0164A-X
150 euros a pair
Posted 22 August 2016 - 05:50 PM
Posted 23 August 2016 - 03:39 AM
Posted 23 August 2016 - 11:00 AM
i put that on my mini and it made the run quite hot in traffic, took it off and the problem went.
Posted 23 August 2016 - 05:06 PM
What year is your mini?
Posted 23 August 2016 - 08:20 PM
After recently stripping the interior out while I cracked on with some welding. As I just have the front seats and an old/tatty/falling apart front/rear carpet so its derivable. This lot under the carpets, behind the dash, behind the rear cards, seat bulkhead, etc really does make a big difference.
Posted 23 August 2016 - 11:10 PM
Another area that needs attention, if you want a real silent Mini, is the hollow crossmember in the bulkhead.
If you only cover above & under it, you will end up with a bare bulkhead facing your cabin = you can see it throu the holes, where the pedal & heat hose comes in.
As its a hollow / bare metal compartment, will it act as a "speaker" and transmit piston noise into your car, so make sure to cover it up (or fill it with foam dipped in waxoil).
Posted 24 August 2016 - 10:47 AM
1968 cooper
Posted 24 August 2016 - 06:16 PM
