It'll be down to the cam that gives the mechanical advance inside the dizzy.
There are different ones.
Under full revs If you have a 13 degree cam, this will give 26 degrees of mechanical advance. (you double the number)
So if the advance is set @ 32 degrees @ 5000 rpm, at rest you deduct the 26 degrees, you get about 6 degrees.
If you only have an 8 degree cam in the dizzy, same scenorio at full chat 32 degrees, this would give 16 degrees advance at rest.
