Ignition Full Advance
36 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 11:21 AM
just been playing with my ignition timing set it to 30 deg full advance
mg metro engine  new stage 3 head mg metro cam lucas electronic dizzy
does that sound about correct comp is a about 9.75 to 10.1
was showing 34 and thought a bit much
does ignition timing change over mileage or always the same once set
and if so does it normally show more retard or advance
#2 tiger99
tiger99
  • 8,584 posts
Posted 18 August 2016 - 11:48 AM
It changes. Wear of the timing gears, chain etc retards it generally but distributor shaft wear makes it fluctuate at random. Points, if you have them, suffer wear of the cam follower, which retards and increases dwell.
But these effects, except for the points, are very small on engines that are in good condition.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 18 August 2016 - 11:49 AM
When you say change, do you mean physically change? Or the ignition advance requirement change?
Ac
#4 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 12:07 PM
Ac
general wear- example say after 10000 miles say was set to 30 but now showing different say 32 due to some king of wear
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 18 August 2016 - 12:29 PM
With a standard dizzy if setting for max advance its worth checking what degree of advance the cam in the dizzy is.
example if you set for 30 degrees max advance with an 8 degree cam , your static advance could be as high as 14 degrees which could give sluggish starting.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 18 August 2016 - 04:02 PM
It does change with wear, usually retardation. If points it can advance.
Ac
#7 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 04:32 PM
Ac
thats interesting to know
after reading vizards book have set it to 32 deg at full advance till dyno
#8 carbon
carbon
  • 2,590 posts
Posted 18 August 2016 - 06:29 PM
Total advance depends a lot on what fuel you're using. Is this with 95 or 99 octane?
#9 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 07:43 PM
its v power with  castrol valvemaster so yes about 99 all up
#10 Spider
  • 14,849 posts
Posted 18 August 2016 - 08:35 PM
Good to see you about Bobby, following your surgury, trust all went well for you mate :proud:
The Total Advance needed will also depend on the Combustion Camber and how the flame front travels across / through it.  For standardish shapes, it's generally around the 28 - 32 range, but some of the more open ones can need more, but just depends on the shape. The RR really is the only place you'll find out.
Be aware too that some additives can reduce the Octane rating too.
#11 racingbob
racingbob
  • 3,061 posts
Posted 18 August 2016 - 08:46 PM
hey Chris good to hear from you, surgery went ok was 5 hours still re-couperating
valvemaster has added 2 octane
#12 Trissy B
Trissy B
  • 381 posts
  • Local Club: Bognor Regis Motor Club
Posted 19 August 2016 - 09:37 AM
Sorry if i'm hijacking the thread but I have just checked mine this morning and had 24 deg BTDC using a strobe at 1500 RPM. I've got a similar but not as good spec as racingbob - only the standard head for me.
The book says 12 deg. BTDC so I retarded it a bit to about that. Now seems a bit boggy at low revs...
Totally confused now!
#13 racingbob
racingbob
  • 3,061 posts
Posted 19 August 2016 - 10:11 AM
if your a bit concerned take it to a dyno like i am, but waiting for Slark to get  back off holiday
can you check it at 3500 - 4000 after reading vizards book i am happy at 32 deg until dyno
always mark the dizzy so you know where you are
#14 Trissy B
Trissy B
  • 381 posts
Posted 19 August 2016 - 10:19 AM
Ok thanks - i've got vizard on the shelf so will give that section a read. Will check it at 3.5-k revs then too.
#15 racingbob
racingbob
  • 3,061 posts
Posted 19 August 2016 - 11:36 AM
well i just checked mini again and shows about 32 full advance
but at 1500 revs vacuum off at the carb only shows 5
