With the frames and skins painted, i set about the task of fitting the skins and then getting the doors to fit well.
The doors were removed when i received the car so i had no idea how well they fitted so ill just assume they were good and work to that.
First thing was to put a new anti drum pad on the inside of the skin
Then i laid the frame onto the skin, clamped the top and folded the bottom corners over. This is so that the skin is held tight to the frame for trial purposes but can still be moved if needs be.
Once i had done this, i popped the door on to see what i had to start with
The gap to the quarter is far from perfect but not a bad start. At least i know that even gaps are achievable with the frame on the skin in this position
I took the door back off again and folded the skin all the way round.
Then welded the top of the skin to the window frame
I haven't welded the bottom of the skin to the frame at this point so it gives me the option to still move the frame in the skin if needs be
So that's one door 90% complete
Next, it goes back on the car
At this point, i fitted the catch and striker and fitted an old off cut of door rubber down the back edge to hold the door level with the quarter.
The gap is good enough for now.
So onto the front and fitting the A panel
With it clamped on, the gap is not too bad. I just need it to be the same width as the back edge at this point
Then I plug welded the A panel tight to the flitch so it can't move allowing me to further tweak the gaps
And then folded it round the flitch
Now the door can go back on again for more tweaking
It is all level and the swage lines match so i finished welding the A panel to the wing
And this is where ill leave this side for the time being. It will be fettled more during prep.
Then onto the other side
Same process as the other side obviously and here it is after it's first trial fit
And tried the A panel too
This side will need a lot more work but as time ran out, ill have to go back to it on Tuesday.
Ben
