Jdimini Restoration/track Day Toy @ Mill Road Garage Isle Of Wight
457 replies to this topic
#61 JDImini
JDImini
  • 683 posts
Posted 22 August 2016 - 09:49 PM
Great work as always, I've just taken delivery of the same rollover jig you're using and your pictures of the shell on the jig have been a great help over the last couple of days as I've been figuring out how to bolt the thing together!
I'm not sure that this one is assembled correctly as i have no instructions.
It is supposed to turn easily by hand with one person but we always struggle at the half way point so it needs two of us to do it
Ben
Hi Ben,
Thanks for the call today
Regarding the spit jig we didn't get it setup right, we bought the self loading/balancing tool but it doesn't work when using it for the mini although we weren't told that when we bought it. If you look at the video on the website you can see the drilled "u" shaped part on the front and back should be should be a "u" not "n" as it is at the moment.
Well I know what I mean
#62 JDImini
JDImini
  • 683 posts
Posted 22 August 2016 - 10:00 PM
Hi Ben, I think we'll try and come over to see the mini on Thursday all being well
#63 carthorse
carthorse
  • 257 posts
Posted 22 August 2016 - 10:01 PM
Ben
Hi Ben,
I got no instructions at all with mine either which nacked me off a bit considering the price of the spit. I'll be even more cross if the loading / balancing tool doesn't work either - I went for this option specifically as the pickup shell is very rear heavy so will probably be a big of a pig to spin.
I'll be hopefully getting the shell mounted and spinning later this week so we shall see how it goes.......
#64 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 August 2016 - 07:06 AM
I look forward to seeing you.
Ben
#65 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 August 2016 - 06:07 PM
Well I have sorted out the front panel problems. The poor one is going back tomorrow and i should be taking delivery of a replacement too so that can go on.
I finished off the other sill.
This meant the flitch repair had to be done
Then there was this join to weld up
And complete
Now all of the underside is repaired, it's time to remove the shell from the spit.
There is work to be done inside the shell and that means me having to get in there which i can't do with it swinging in the air :lol:
Popped it on a couple of pallets as axle stands aren't really safe. There is so little weight in the shell that i doubt it would have stayed on the stands for long with me climbing in and out.
I cleared my bay and put it back for the next leg
There isn't much to do inside the shell but some welding non the less.
There is not to be an ashtray in the back so i welded up the mounting holes
The handbrake mounting had torn away from the crossmember so that was fixed too
And as there are no dash rail trims going back in, the mounting holes for the top one were filled in as well as the ends reshaping where they were bent out
I did the other side too..
I then pottered a bit as Colin was using the welder.
Cleaned one half of the floor back
Then thought i would start prepping for the new front panel instead
I cut the slam panel off
And cut the remains away from the wing and seam on one side
And then ran out of time.
I did also do some repairs to the front edge of the inner sill on the o/s where i had to cut it away to get the old repair patch off when i did the flitch but no pictures of this.
Thanks for looking
Ben
#66 Carlos W
Carlos W
  • 10,115 posts
Posted 23 August 2016 - 06:59 PM
Superb as ever mate.
I love the sill to flitch join. It's so neat
#67 Gijs
Gijs
  • 15 posts
Posted 23 August 2016 - 07:03 PM
Hi Ben,
Great work, especially your welding. How do you prevent warping of the metal and how do you dress them  and keping the metal so flat?
Gijs
#68 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 August 2016 - 08:12 PM
Hi Ben,
Gijs
Regards to warping, i tend to go slow over larger areas and just keep the work piece cool. i would do a short run of weld, cool with compressed air gently and then do another short run. It's also a good idea to switch round so i would weld a bit at one end, then a bit the other end and just work round.
To dress the welds, i use a smart repair grinder with Roloc sanding discs at work but a flap disc on a grinder is good and so is a grinding stone if you have lots of material to remove. I also use carbide burs on a die grinder if there is grinding/shaping to do in confined spaces.
The way i work is that the neater the weld, the less cleaning and shaping there is to do afterwards. For instance, a typical plug weld will take me 5 seconds to grind flat using the 36 Grit Roloc discs which is handy when you have lots to do and time is of the essence.
Ben
#69 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 August 2016 - 08:13 PM
Cheers Carlos!
#70 wingnut
wingnut
  • 468 posts
Posted 23 August 2016 - 09:06 PM
Superb work ben.I  see why you get so much work
#71 JDImini
JDImini
  • 683 posts
Posted 23 August 2016 - 09:38 PM
Hi Ben, your work is looking great as always - not sure what else to say the mini is going to be fantastic when it's done
PS love the fiat 500 in the back of one of the pictures
#72 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 August 2016 - 08:28 AM
The Fiat belongs to one of our regulars. We look after his fleet which also includes a T2 bay camper and a Morris Minor Traveller.
#73 Baldspeed Racing
Baldspeed Racing
  • 1,204 posts
Posted 24 August 2016 - 09:14 AM
love builds like this, so much tidy work and attention to detail. Always good to see the updates on it. Keep up the epic work
#74 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 August 2016 - 05:19 PM
Here is a better pic of the little Fiat. They really are very tiny.
First thing, I removed the front panel remains from the other wing
Before starting on the engine steady bracket
It is perfectly serviceable and definitely strong enough but pretty scruffy and the customer wanted it changed so off it came
Typical.....
Oh well, it is a pretty simple job to sort that
Cut out
Make a new piece
weld it in
And grind it up
Then the new steady bracket needs putting on so i had to mock up the plate that goes under the master cylinders and the steady bar
And once welded, i removed the mocked up parts and cleaned it up
So now i'm prepped for the front panel, i need a subframe
But all of that is still attached so needs to be seperated.
So off came the hubs
And out came the engine
I split the put joints at the diff instead of at the shaft so as soon as i lifted the engine, it dumped it's oil everywhere.
oops...
But interestingly, when i drifted the roll pin out that attaches the selector rod to the box, it flew out with one strike! I couldn't believe it as every other one i have done was a nightmare.
To get the subframe bare, i put it on the rolling bench and took the remaining parts off
Once stripped, i de-greased it so it can dry off overnight
Needless to say, it will be stripped and painted before final fitting.
I mentioned earlier on that Colin had been working on the door frames. Well he has had to take a few days off so i shall be finishing them.
Here is the frame that he repaired
It's had a complete new bottom in it as well as a repair where the lower hinge bolts as it was split. This was the better one of the two which is typical.
Ill get on with the other tomorrow so that I can paint the inside of the frames and skins body colour before they become one.
Thanks for looking
Ben
#75 JDImini
JDImini
  • 683 posts
Posted 24 August 2016 - 08:36 PM
Hi Ben, the attention to detail for the engine steady is amazing and the bottom of the door and and...  and the subtle coca cola product placement I hope you're getting paid :-)
Nice pic of the fiat, one of the few cars that makes the mini look big
