Jdimini Restoration/track Day Toy @ Mill Road Garage Isle Of Wight
457 replies to this topic
#316 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 October 2016 - 06:01 PM
Everything done this morning was done in the lead up to this moment
So that was
Fill with Oil
Fill with coolant
Finish fuel lines and overflow
make up and fit clutch master to slave pipe
Add petrol
Then this afternoon was spent finishing building up the n/s hub
And then i adjusted the rear suspension and ten greased the ball joints, radius arm pins and top arm pins.
Wheels going on tomorrow after the brakes are bled and then it can go outside for a piccy.
Ben
Edited by Ben_O, 17 October 2016 - 06:02 PM.
#317 JDImini
JDImini
  • 679 posts
Posted 17 October 2016 - 08:11 PM
Hi Ben well done for getting the mini running, it sounds interesting :D
Looking forward to seeing it outside
just checked the weather tomorrow
Attached File  weather.jpg   85.98K   2 downloads
and thankfully it looks ok  :D
#318 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 October 2016 - 08:47 PM
It needs setting up a bit but for a first start, i'm pleased with it.
Hopefully it will go outside under it's own steam. If not, ill push it :lol:
#319 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 October 2016 - 06:40 PM
This morning, i bled the brakes and clutch.
And when that was done, i adjusted the handbrake and refitted the wheels and now the Mini is finally off of the axle stands
So the Mini now starts, drives and stops.
I couldn't get it outside at this point as Colin was working on a Range Rover in the doorway so i helped him get that done in the hope that it would be out of the way so i could get the Mini outside for some pictures.
Well that didn't happen so i decided now would be a good time to get the paintwork flatted in preparation for polishing
The whole car is now flatted ready for machine polishing tomorrow morning.
And a random shot of the engine bay
Ben
#320 Carlos W
Carlos W
  • 10,114 posts
Posted 18 October 2016 - 06:54 PM
Superb work Ben.
Any handbrake turns?
#321 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 18 October 2016 - 06:59 PM
Get us an out-in-daylight shot Ben instead of those flouros!
#322 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 October 2016 - 07:37 PM
Superb work Ben.
Cheers Carlos.
No handbrake turns here although that may have been the way to get it out past the Range Rover  :shifty:
#323 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 October 2016 - 07:38 PM
Tomorrow, i will most certainly get it out. Once i have polished it.
Weather dependent of course
Ben
#324 nicnoo
nicnoo
  • Just Joined
  • 212 posts
  • Local Club: south warwickshire minis
Posted 18 October 2016 - 08:29 PM
Excellent  build, just finished reading. you've also made up my mind about tweed or Yukon grey. looks stunning
#325 JDImini
JDImini
  • 679 posts
Posted 18 October 2016 - 09:06 PM
GREAT!
#326 carthorse
carthorse
  • 257 posts
Posted 18 October 2016 - 09:31 PM
Love the 'to do list' taped to the back window. It's so easy to forget vital stuff like torquing up the hub nuts when you come to the end of something like this, and the consequences of forgetting could be very expensive !
#327 JDImini
JDImini
  • 679 posts
Posted 18 October 2016 - 09:38 PM
weather looks good for tomorrow. Make sure Colin shifts the other cars out of the way so the mini can see the light of day :D
#328 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 October 2016 - 09:41 PM
I have gone round torquing up everything else but my big torque wrench which goes high enough for the hub nuts was at home so i needed to remember they still need doing tomorrow.
I think there was only 2 things on the list, everything else is done!
Just the door trims, harnesses and speedo to fit now.
Oh and one more thing.... oh yes.. the bonnet :lol:
Ben
#329 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 October 2016 - 09:42 PM
And the sump guard
#330 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 October 2016 - 12:56 PM
