I started off the day by sorting out the seats. They are bolted to subframes that use the existing mounting points and lock down onto the original hoops in the floor. Unfortunately, the hoops are too tall so although the seats lock down, they have quite a bit of up and down movement which wasn't acceptable,
I measured the distance between the locking pin and the top of the hoop and then removed this amount (15mm) from the height of the hoops and now they lock down tightly. i have left a small amount of play as i intend to use something between the back of the frame and the floor to prevent it from becoming scratched/scraped.
No picture of the modified hoops but here are some of the other seat fitted.
Now i can actually sit behind the wheel, i could start to experiment with suitable positions for the rev counter.
here looks good to me
But Darren, if you would prefer it somewhere else, just tell me where. There is still the dash cards/liners to go in so i think that it will look great against the flat black background instead of wires and painted metal.
With that done, i changed the normal bolts in the steering column mounts for the correct shear bolts and fitted a few grommets etc here and there
And then put the passenger door together.
Installed some riv-nuts for the wing mirror
And then installed that
I think the interior is looking great
I am part way through fitting the windscreen and that will be finished in the morning and then hopefully the new hub will arrive and i can get the Mini rolling.
Ben
