Jdimini Restoration/track Day Toy @ Mill Road Garage Isle Of Wight
457 replies to this topic
#211 JDImini
JDImini
  • 679 posts
Posted 20 September 2016 - 09:43 PM
Ben,
Can you let me know how you get on with those handbrake quadrants? I've got a set and the fit is awful. There's a mm play between the hole in them and the pin.
 Hi Ben
last post was as a followup from this one from Steve220
#212 JDImini
JDImini
  • 679 posts
Posted 20 September 2016 - 10:12 PM
Can I ask why a weld in cage wasn't used for this? Good choice on the engine spraying imo
Hi Matt,
it's only being used for a bit of fun on a few track days and Ben has welded in strengthening plates. I didn't think it needed a welded in cage also much more difficult to install as I understand
cheers Darren
#213 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2016 - 07:14 AM
Hi Ben,
if any of the kit I bought isn't up to scratch, in your opinion please let me know and I'll get it changed, for example are the minifins OK they weren't the the most expensive but equally they were from one of the bigger mini suppliers so hopefully not cheap rubbish
by the way the protech shocks look good
Also interested to know if the hand brake quadrants were OK
Darren
Everything so far seems to be fine but i will let you know if anything comes up.
The handbrake quadrants are fine and work well. There is a mm or so up and down movement in them but this is normal.
Ben
#214 Junior Mini
Junior Mini
  • 313 posts
Posted 21 September 2016 - 08:02 AM
Hi Ben,
Can I ask what sealant you used for this?
Was it Silkaflex?
Could you use this to reinstall the window regulators as well or could you recommend some more suitable?
Thanks.
#215 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2016 - 01:36 PM
Hi Ben,
Was it Silkaflex?
Thanks.
It is a non-setting windscreen sealant by 3M which is ideal for this sort of thing as it stays watertight but can be peeled off if the piece needs to be removed where as sikaflex would be a more permanent bond and difficult to remove
Ben
#216 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Oh, and it would be suitable for the window regulators too
Ben
#217 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2016 - 04:42 PM
Not too much actual progress on the car itself today as i spent a lot of the day sorting out the last of the parts and searching online and with suppliers for the last of the illusive parts which all seem NLA.
Anyhoos i got all the body sealing hardwear on
And installed the switches
Then the choke and heater cable
Then the blower unit
I also put in the water pipes for the heater matrix and the de-mister vents
The steering column bracket turned up (thanks Josh) so i put the column, switches, cowling and steering wheel in
I was going to fit the seats but there just wasn't time today
I did get the horrible little clevis pin in for the clutch master to pedal which no matter how many times you do one, they are always a bugger. At least that's done out of the way now.
I only have the afternoon to spend on the Mini tomorrow as I'm needed on the spanners for a couple of hours in the morning.
Ben
#218 CharlieNZ
CharlieNZ
  • 69 posts
Posted 21 September 2016 - 07:30 PM
I love how the switches look, such a neat job. Now all it needs is the heater deleting but I guess in England that isn't an option...
#219 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2016 - 08:06 PM
The weather here is the main issue. If nothing else, the heater would be needed for demisting the screen, not that a Mini heater is very good at that :lol:
#220 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 21 September 2016 - 08:54 PM
Is that a DSN drop bracket Ben?  I'm loving the switches like that too, they look just right.
#221 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2016 - 09:01 PM
I don't think the bracket is DSN. It was in a plain bag with a minispares stock sticker on it It came with all the parts that Darren had bought before we got the car in.
Thanks for the compliment on the switches, i think they came out well.
Ben
#222 JDImini
JDImini
  • 679 posts
Posted 21 September 2016 - 11:26 PM
Hi Ben,
jumping in a bit late this evening, totally agree with Mini Manannán and CharlieNZ about the switches
great job Ben
Edited by JDImini, 21 September 2016 - 11:32 PM.
#223 JDImini
JDImini
  • 679 posts
Posted 21 September 2016 - 11:31 PM
Hi CharlieNZ, we did talk about ditching the heater as well but decided it was better to be able to see out of the windscreen on a frosty or damp day both of which are quite frequent in the UK
by the way Jack is looking to travel to NZ at some point this year, what's the must do thing over there?
cheers Darren
#224 JDImini
JDImini
  • 679 posts
Posted 21 September 2016 - 11:34 PM
Don't think the steering wheel is going to last long, doesn't really go with the grey and black theme of the mini
#225 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 September 2016 - 07:05 AM
100% agree
