Jdimini Restoration/track Day Toy @ Mill Road Garage Isle Of Wight
457 replies to this topic
#196 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 September 2016 - 05:52 PM
The roof is Rover Paul Smith Black
It sounds like one of those old M&S adverts
"The roof is not just black, it's Rover Paul Smith black"
We thought we would keep things Austin/Rover/Morris  ;D
#197 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 17 September 2016 - 07:15 PM
Lovely work. Looks fantastic.
#198 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 September 2016 - 08:30 PM
Cheers Jamie
#199 JDImini
JDImini
  • 679 posts
Posted 18 September 2016 - 08:14 PM
It needs to be used and enjoyed.
If it get's damaged or scratched, then it can be sorted out easily enough
I really hope that Darren and Jack do enjoy the car when finished.
Ben
Hi Ben, we will definitely enjoy it
#200 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 September 2016 - 05:27 PM
So the rebuild begins.
first job was to run the fuel and brake lines and the battery live cable.
There was a small problem with the brake line kit that was supplied.
The main front to rear one was too short.
Never mind, we had a coil of copper pipe in stock so i made my own
With them installed, i fitted the steering rack
And the rear subframe
Then i hooked up the rear brake lines
Then fitted the radius arms and suspension
Next up, i fitted the rear loom
And then the front subframe
That's it for today.
Ben
#201 Carlos W
Carlos W
  • 10,114 posts
Posted 19 September 2016 - 05:46 PM
Shiny shiny
#202 JDImini
JDImini
  • 679 posts
Posted 19 September 2016 - 09:07 PM
Hi Ben,
Are you a man or a machine? I won't tell you how long Jack and I spent trying to fit the rear subframe :shy:
The build is looking fantastic
Edited by JDImini, 19 September 2016 - 09:33 PM.
#203 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 19 September 2016 - 09:28 PM
Luvly jubbly
#204 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 September 2016 - 09:38 PM
Hi Ben,
ha ha.
Had a slight issue with the rear trunnions as you pointed out at the beginning but a bot of adjustment had them fitting well.
Ben
#205 StuM
StuM
  • 140 posts
  • Local Club: Box Hill Mini Club
Posted 20 September 2016 - 09:24 AM
This is looking great.  Also gives me lots of reference photos for my rebuild which is awesome - thanks!
#206 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 September 2016 - 07:54 PM
More steady progress today.
I did spend quite a lot of time cleaning up parts and giving them a coat of paint but besides that, i got the handbrake fitted and the cable routed
I got the front loom installed
And the pedal box assembled and fitted
It's starting to come together now
And Darren, look what came in today..
:D
I had planned to get the tank installed but after going to fit the n/s/r lamp, i noticed that the rubber seal has some splits and cracks so ill have to order some new ones before i can continue with that.
Tomorrow, ill see if i can get the interior finished.
Oh and Darren, Colin wants to get the engine painted so do you want it all green like this
so that would be engine, head, flywheel housing and gearbox
Or do you want it part green like this
So just the engine block and head.
Ben
#207 JDImini
JDImini
  • 679 posts
Posted 20 September 2016 - 08:45 PM
Hi Ben, Just engine block and head green please, with gearbox and flywheel housing silver and the rocker cover as it is.
or perhaps it should be red to give us an extra 10hp - only joking
#208 JDImini
JDImini
  • 679 posts
Posted 20 September 2016 - 08:55 PM
Like the 1500 midget, I had a P reg pageant blue 1500 midget in '89 - I loved that car :wub:
My 1275 midget needs some TLC and then it'll be great
Edited by JDImini, 20 September 2016 - 09:02 PM.
#209 mattmiglia
mattmiglia
  • 515 posts
Posted 20 September 2016 - 09:26 PM
Can I ask why a weld in cage wasn't used for this? Good choice on the engine spraying imo
#210 JDImini
JDImini
  • 679 posts
Posted 20 September 2016 - 09:36 PM
Hi Ben,
if any of the kit I bought isn't up to scratch, in your opinion please let me know and I'll get it changed, for example are the minifins OK they weren't the the most expensive but equally they were from one of the bigger mini suppliers so hopefully not cheap rubbish
by the way the protech shocks look good
Also interested to know if the hand brake quadrants were OK
Darren
