Jdimini Restoration/track Day Toy @ Mill Road Garage Isle Of Wight
457 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 August 2016 - 12:31 PM
Hello all.
I have recently been to Surrey to collect a Mini from fellow TMF member JDImini and bought it back to our bodyshop here to the Isle of Wight for restoration.
This will be a build diary for the car much like i did with the last one we did back in December.
The plan is to build a stripped out track day toy with full roll cage, bucket seats and 7.5" brake conversion for 10" wheels.
After the body work is complete, we will be building it back up with fresh parts. Engine is staying 998 at the moment but the customer has plans for that in the future..
The shell is very good, we have received it already stripped out and for a 1989 shell, it is in incredible condition and all original except from an A panel that has been replaced at some point.
Anyway, here are the first set of pictures.
Panel wise, we will be replacing the front panel, the A panels, the lower flitches and some repairs to the tops of the quarter panels
Then it will be resprayed inside, out and underneath in either Smoke grey or Tweed grey.
So with work starting, the first thing to do was degrease the underside of the floors to assess what needs to be done.
The waxoil under the grease has done a remarkable job of preserving the floors
I only started today late morning so nothing else to report just now but this afternoon, i shall strip back the floors underneath and post up another update this evening.
Ben
#2 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 11 August 2016 - 12:37 PM
Nice one Ben, I loved the Mini Cooper you did previously as the updates are thick and fast and the workmanship top quality.
Another Mini in very safe hands.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 August 2016 - 05:07 PM
Well i began to sand the floors this afternoon.
The plan was to clean up the surface rust here and there and then key up the rest but whilst cleaning up, i noticed a fair amount of spider trails of rust under the paint so i am going to have to more or less bare metal the whole floor.
So one side is complete bar a small amount of shot blasting in some of the seams.
The plan tomorrow is to strip the rest of the floor and boot floor, remove the A panels and inspect the hinge panel/A post. By the end of the day if all goes to plan, the underside will be completely prepped and ready so i can roll it back over and begin the repairs topside.
Thanks for looking
Ben
#4 mattmiglia
mattmiglia
  • 515 posts
Posted 11 August 2016 - 05:08 PM
Hi Ben could you PM an email address I can contact you on for a quote please.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 August 2016 - 05:24 PM
Sure, I'll do it now :-)
Ben
#6 JDImini
JDImini
  • 679 posts
Posted 11 August 2016 - 09:26 PM
Hi Ben,
Great to see the work starting on the mini, a great tonic for the post holiday blues. Very pleased to here no big surprises with the bodywork, yet. Looking forward to the next update.
Darren
#7 alchall
alchall
  • Just Joined
  • 604 posts
Posted 12 August 2016 - 09:22 AM
Looking forward to following this one Ben!
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 August 2016 - 12:29 PM
So this morning, i have been continuing on with the floors.
This is the rust trails i was talking about
This seemed to be worse on the O/S floor which required all of the floor to be stripped back to bare metal. The N/S was much better but had been covered in a thin layer of grease possibly from an oil leak and this must have protected it better.
The best way to remove the rust tracks is a combination of spot blasting, die grinding and wire wheels.
The sealer over the seams looked in great shape but should always be removed with jobs like this to make sure that no rust is beneath.
There always is
Once I was happy that every trace of rust was removed from the floors i cleaned it all down
And then turned my attention to some odd holes in the floor. The must have been drilled for screws but i'm not sure what
So i welded them up
And ground them down
And then put a single coat of Zinc over the floors to protect it for the time being.
Next, ill remove the A panels and clean and inspect the flitches.
Ben
#9 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 12 August 2016 - 01:39 PM
As you mentioned earlier Ben that shell is in fantastic condition for an '80s shell. There are a lot of Mini owners who would be jealous of those floors and sills, and that's before you work your magic.
#10 carthorse
carthorse
  • 257 posts
Bookmarked - I can see another valuable inspiration / reassuring me it's possible thread coming on!
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 August 2016 - 02:28 PM
Cheers fella's :-)
Ben
#12 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 August 2016 - 03:51 PM
Change of Plan, i decided to tackle the boot floor instead whilst the shell was on it's side.
There are a couple of obvious areas of surface rust but on the whole very good.
Again, the sealer looked spot on but i removed it anyway.
First thought was that i was wasting my time....
This is the seam between the top of the heelboard and the seat pan
Clean a bit further along and there is rust after all so worth doing
This is behind the rear valance once i removed the wax  from this area
Some minor spots of corrosion here too so they were removed using a combination of the die grinder and spot blasting to get in the seams.
And after completing half of the floor, time has run out again so i have applied a coat of zinc onto the bare areas
More updates on Monday!
Ben
#13 Steve220
Steve220
  • 5,037 posts
  • Local Club: BMC
Posted 12 August 2016 - 04:35 PM
Epic work! Subscribed.
#14 JDImini
JDImini
  • 679 posts
Posted 12 August 2016 - 09:21 PM
Hi Ben,
The mini is looking amazing, not sure we're ever going to want to drive it once you've finished it :D
#15 James_eaton_thewholething
  • 1,063 posts
Posted 13 August 2016 - 01:15 AM
Yes more of bens work to look at. ๐Ÿ˜Š
