Replacing Heater Matrix
3 replies to this topic
#1 SRO
SRO
  • 12 posts
Posted 09 August 2016 - 06:23 PM
How do you replace a heater matrix in a 1995 Mini Cooper?
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 09 August 2016 - 07:27 PM
Drain the coolant system then place a shallow bowl under the two heater hoses in the passengers footwell and remove the two heater hoses. There should be two small cross headed screws on the same side remove these and then the heater matrix should slide out. Refitting is the reverse procedure.
#3 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 09 August 2016 - 08:49 PM
As above but the first thing i do is remove the passenger seat  and the front carpet as it makes the whole job a lot easier. .Might be worth getting new metal pipes where the rubber ones go over incase yours are corroded.
Edited by minimat, 09 August 2016 - 08:50 PM.
#4 FlyingScot
FlyingScot
  • 2,664 posts
Posted 09 August 2016 - 09:13 PM
Check these, they corrode.....as Nick and I commented in your original thread
http://minispares.co...c/JEP10008.aspx
FS
Edited by FlyingScot, 09 August 2016 - 09:15 PM.
