Thanks Lawrence.
I used to run a set of big Cibie Oscar spotlamps, with 180W lamps fitted and the connector never complained in the slightest. No spotlamps this time, so even better.
Posted 10 May 2017 - 08:42 AM
Thanks Lawrence.
Posted 10 May 2017 - 02:41 PM
Posted 10 May 2017 - 03:19 PM
That ring needs to move with the shaft, and mine was a push fit over the shaft nicely. Cant remember if I machined the center hole slightly, perhaps I did.... I left the 3 wee prongs though and thats what I used to key into the connecting piece I machined.
I made up a piece to go between the wheel boss and the white plastic cancelling ring to ensure it connected and moved. Get the distance right between the boss and stalks for it to move and cancel freely, and weld it in place.
My steering lock works just fine aye. I did narrow the locking peg a wee bit so it would fit the slot in the shaft, but it fits and works just fine. You turn up the same shells like I did and drill the hole for the locking peg and its surrounding casting to fit into?
Edited by micraminiman, 10 May 2017 - 03:25 PM.
Posted 10 May 2017 - 05:05 PM
Posted 10 May 2017 - 06:03 PM
may just be easier to make a new half to the c clamp on the ignition barrel thats what i did :)
Posted 11 May 2017 - 11:05 AM
Completed the front brake pipes last night. Added a joiner piece into the line from the master cylinder, so its easier to remove the front subframe at a later date if required. Also routed the pipe round the rear of the master cylinder to keep it away from the inlet plenum, which is close to the unions on the cylinder already.
Will be moving on to the rear brake line this evening.
Posted 15 May 2017 - 11:28 AM
Engine cleaned and painted this weekend. New manifold studs in place.
Posted 15 May 2017 - 11:32 AM
Engine back in the Mini again and re-assembly begun.
Still waiting on my Allspeed driveshafts yet, but at least the left side inner CV joint fits in place now. The boot is tight to the bottom of the subframe tower though. Its got 5mm of clearance just now, but can get that larger if I drop the rear engine mount on its slotted mount a wee bit.
Posted 16 May 2017 - 02:24 PM
Last night was spent wrapping the exhaust manifold with fiberglass tape. What a messy job, even with the bandage soaked in water overnight....
Fitted in place, and bolted up using new studs, manifold nuts and new gaskets.
Alternator was re-fitted afterwards, and the radiator in place temporarily as I'm waiting on a new thermostat arriving first.
Posted 01 June 2017 - 06:59 AM
Success! The engine started and runs lovely.
This video by my young son is the genuine first crank and start after cranking minus fuel to get oil pressure first.
One happy lad here!
Posted 16 June 2017 - 10:35 AM
So the driveshafts have arrived from Allspeed, and are fitted.
Insurance is sorted through Adrian Flux, all good.
MOT tomorrow hopefully if my tester has a spare 3/4 hour.
Still waiting on my new carpet set to arrive, but thats just an added extra! lol
Here are the latest pics.
Wheels painted, tyres fitted this afternoon and get a wee test drive.
Edited by micraminiman, 16 June 2017 - 10:40 AM.
Posted 19 June 2017 - 09:58 AM
Well thats the Nissan Mini on the road.
MOT passed with no advisories early on Saturday morning. Taxed and insured, and it was time to drive!#
Have now done nearly 200 miles in it and its great. The engine runs smooth, but hit the throttle and it turns into an animal. Really pulls very strong in every gear.
Overall very happy indeed with how its all gone.
Posted 03 August 2017 - 12:57 PM
Happy to report that nearly 2000 completely trouble-free miles have been done since finishing the conversion. Very happy with it, but would now like to extract a wee bit more power from the unit. I like the idea of a supercharger, but thats a bit off yet!
Only small mod was to add a head-steady shock absorber from a Honda to make the engine movement slightly less when going on and off the throttle pedal.
Posted 03 August 2017 - 07:17 PM
That didnt take long lol
Posted 04 August 2017 - 05:47 AM
Haha, aye, could do with just a wee bit more poke in 3rd 4th and 5th I reckon, to maximise the fun factor.
It goes very well indeed as it is though, its not a complaint! Cash flow, or lack thereof will put these plans to bed for a while yet though! lol
0 members, 6 guests, 0 anonymous users
