Wynns Super Charger Oil Addative
Posted 25 July 2016 - 04:43 PM
I think it makes the oil thicker looks like thick treacle.
Posted 25 July 2016 - 04:45 PM
Sounds horrible and potentially a problem ..
Posted 25 July 2016 - 04:49 PM
Think it could cause problems?
Posted 25 July 2016 - 09:03 PM
Sounds like 'snake oil' to me. Normal good quality 20w50 mineral is all you ever need with no additives. Change it every 2000 to 2500 miles.
Posted 25 July 2016 - 09:44 PM
I put some in .
Why what problems are you trying to hide?
Posted 25 July 2016 - 10:05 PM
Its handy for worn engines, will increase oil pressure and reduce crank knock.
Posted 27 July 2016 - 01:08 AM
I used it in a well worn Cavalier diesel, and it did no harm at all. However, that did not share the engine oil with the gearbox, unlike the Mini.
I also ruined an A+ engine by using an additive called, I think, Slick 50. It contained PTFE, which may have broken down into hydrofluoric acid as it made the plating on the bearing shells peel off, so the crankshaft was badly grooved. The inside of the gearbox casing was as clean as the day it left the factory, if not cleaner, as all the usual deposits were dissolved.
Best to avoid all additives unless they are being used for a specific purpose for which they are known to actually work. Many of them were invented when oil was of relatively poor quality by today's standards. They are much less necessary now.
Posted 27 July 2016 - 06:07 AM
I got scared so I did an oil change after using it a week with it in.
I put in castrol 20w50.
Posted 27 July 2016 - 11:40 AM
Stick with it till at least the next oil change.
Posted 27 July 2016 - 12:34 PM
Posted 27 July 2016 - 04:56 PM
That should be ok, but it is more usual to use 20w40. Having said that, I often used 20w50 in what I now know to be the mistaken belief that higher viscosity is good. It is not as simple as that...
20W50! Or you thinking 10W40 tiger99?
20W40 is motorcycle oil.
Edited by gazza82, 27 July 2016 - 04:57 PM.
Posted 27 July 2016 - 05:33 PM
So will a new set of rings and bearings!
Posted 27 July 2016 - 06:41 PM
Posted 27 July 2016 - 08:47 PM
This a lot cheaper and easier though
Posted 27 July 2016 - 09:33 PM
I've seen she'll 20w 50
On the shelf also here in italy .iI've found penrith. really good.
