Cg13 All Speed Shafts
Posted 24 July 2016 - 10:47 AM
Posted 24 July 2016 - 11:03 AM
Posted 25 July 2016 - 11:00 AM
Yes, more info required! I'm just starting to think about making up my driveshafts and could hopefully learn from your (bad) experience.
Posted 26 July 2016 - 05:21 PM
Posted 26 July 2016 - 10:28 PM
This appears to be the accepted way to do them.
I take it yours weren't welded under the sleeve?
Posted 26 July 2016 - 11:35 PM
Posted 27 July 2016 - 09:45 AM
Is it salvageable?
Posted 27 July 2016 - 10:14 AM
The reason her said he had the threaded bar in the middle was that if the weld broke the threaded bar would prevent total failure apparantly
Posted 27 July 2016 - 11:30 AM
The chap who made mine ran a high tensile threaded bar through the middle and said I need to just make the final adjustment if I want to align the splines and then weld up the v
I'm not sure why you would need to align the splines.
Welding high tensile threaded bar will have an effect on the strength of the bar. Low carbon steel threaded bar would achieve the same thing but would be difficult to maintain the "true" between the two shaft ends.
There are plenty on here who have welded shafts and are running much more power than a Micra conversion. How have they done them?
Posted 28 July 2016 - 12:29 PM
